    MMM-Embed URL centered on fullscreen_above?
    12 Posts 3 Posters 89 Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @sdetweil
      @sdetweil @bkeyport
      Hi… I’m here 😉
      Sorry, but I need some more information.
      Can you share your config and a screenshot which shows the current view and a hint what you want to achieve please?
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @wishmaster270
        @wishmaster270 I think the requirements are here
        https://forum.magicmirror.builders/post/130079
        Don’t know config
        • BKeyportB Offline
          BKeyport Module Developer @wishmaster270
          @wishmaster270
          Config stub:
                                  module: "MMM-EmbedURL",
                                  position: "fullscreen_above",
                                  classes: "camera1",
                                          updateInterval: 0,
                                          animationSpeed: 0,
                                          appendTimestamp: false,
                                          attibutes: [],
                                          embed: [
                                                  "http://192.168.0.7/picture/1/frame/"
          The camera stream should be centered left/right. The camera feed is 4x3. (scaled from 640x480 due to how I have to get the feed at this time) and will always stretch the vertical to 100%
          (note: screenshot isn’t actual screen resolution)
            sdetweil @BKeyport
            @BKeyport also, you should be able to see the html element used to display the web view in the developers window elements tab and relocate it w css
            • BKeyportB Offline
              @sdetweil Indeed, I can see it in develop mode, but everything I’ve tried has failed, which is why I’m here.
              S wishmaster270W 2 Replies Last reply Reply Quote 0
                sdetweil @BKeyport
                @BKeyport I’m sure you need
                .MMM-EmbedURL Element-name {
                   position :absolute;
                   left:10vw;  /* move 10% towards the right +/
                  wishmaster270 Module Developer @BKeyport
                  @BKeyport
                  Instead of setting the spacing with absolute values (like sam does) you can try to set the wrapper which contains the embedded elements to add equal spacing if the elements do not need the whole space.
                  The wrapper is a flexbox container:
                  .MMM-EmbedURL .embed .embededSubWrapper0 {
                    justify-content: center;
                  • BKeyportB Offline
                    @wishmaster270 Doh! Was using the wrong css item.
                    <internally screaming at CSS>
