    Voice control
    Scheduled Pinned Locked Moved Upcoming Features
    8 Posts 2 Posters 3.2k Views 2 Watching
    • V Offline
      videogame95
      When will be a new voice control can I use Alexa voice control I’ll like add voice control to turn
      My MMM-pages
      If something needs a key or api could module maker put a link on the page to get the link or key api etc
      As I had great difficulty finding the token for national Rail uk. Any help in finding. Tokens or api keys etc.
        sdetweil @videogame95
        @videogame95 alexaVoice control depended on a fake electric outlet from Wemo. Belken bought Wemo years ago and just recently the Alexa plugin for this capability was removed because it was using old Alexa interfaces.
        Mmm-pages only shows or hides modules, it doesn’t have any info about the module requirements. You have to read each module documentation, their README.md file,
        • V Offline
          videogame95
          Do you or any one know if a new voice control is going come out or is someone building one I think someone thire may a fix to google assistant or new one was coming out? i’m not sure as was it was weeks ago ?
            @videogame95 currently there is no one developing a new voice module.
            • V Offline
              videogame95
              wiped out oh no I know default is to boot to sd card so I thought i was building my magic mirror on to the sd card I was wrong. when i booted up my pi not sd card showing as it should so must be sd card so ill make back up onto usb stick all fine until I reboot it and loads up I can see the sd card so think it has every thing on it i start to copy sd to nvm drive then run it
              but it was wrong and I wiped everything off the drive!
              We live and learn ha ha hope you like
                @videogame95 I spent a few hours last winter trying to boot sd card on my pi5. Then realized it had nvme drive… Doah!
                • V Offline
                  videogame95
                  I’ve started again a little bit each day .
                  I’ve heard of mycroft voice control do know anything
                  about it and if so could i use this to control turning pages over like turn to page 1.
                  when ext MMM-pages was up and running i used EXT-bugsos something
                  Any help please
                    @videogame95 always make backups
                    You can use my MagicMirror-backup-restore scripts
                    I have also heard of Mycroft. , have no info
                    looking for mycroft the initial project has been ended.
                    others have taken over for the future…
                    one would have to build an interface(module) to MagicMirror from its implementations
