    For inspiration: A DAKboard clone
    11 Posts 4 Posters 7.4k Views 8 Watching
      mrchips83
      Took me a few months but finally have my MM version of our old DAKboard up and running how I want it:
      Modules:
      Wallberry Theme (to mimic DAKboard’s style as closely as possible)
      MMM-MonthlyCalendar (displaying our shared Google family calendar)
      MMM-HomeAssistant (for screen auto-on/off based off HA movement detection)
      MMM-BackgroundSlideshow (pulling top-rated photos from my Synology NAS)
      J 1 Reply Last reply Reply Quote 16
      • P Offline
        pocketknife
        hi there - would you be willing to share your [non private] config.js for it?
          Junoman @mrchips83
          @mrchips83
          Looking Good.
          That is pretty much what I was trying to accomplish 2 years ago but gave up.
          MagicMirror is fantastic, but ideally just looking to build a calendar with photo transitions.
          Spent much time trying to configure our calendar on our cell phones to sync to the cloud and show up on the screen - got part way there.
          Another big challenge that would be so perfect is date/time photo folders.
          For instance automatic winter photos in winter, summer photos in summer and photos of a specific person on their birthday.
          Easy to create folder arrangements to do this, but no code to schedule.
          Layout was also a challenge with MM to mimic DAK, but came very close. Let’s admit that DAK is an impressive clean and nice look.
          Anyway, congratulations and please keep us updated when you are finished.
          Would love to see your final display!
          Thanks for sharing too. You might have inspired me to jump back into this.
            mrchips83 @pocketknife
            @pocketknife
            Sure can: I’m travelling next week but will share it when I get back
            B P 2 Replies Last reply Reply Quote 1
              botts85 @mrchips83
              @mrchips83 Are you doing anything to make the text visible on top of lighter colored photos?
              M J 2 Replies Last reply Reply Quote 0
              • P Offline
                pocketknife @mrchips83
                @mrchips83 said:
                @pocketknife
                thank you so much!! Cheers! Rich
                  mrchips83 @botts85
                  @botts85
                  No: haven’t really found that to be an issue. I guess it could be tweaked in the CSS?
                    @pocketknife
                    Here you go. It’s pretty untidy (could do with a good bit of pruning!) but hope it helps:
                    /* Config Sample
                     * see https://docs.magicmirror.builders/configuration/introduction.html
                     * and https://docs.magicmirror.builders/modules/configuration.html
                     * You can use environment variables using a `config.js.template` file instead of `config.js`
                     * which will be converted to `config.js` while starting. For more information
                     * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                    let config = {
                    	address: "localhost",	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                    	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                    	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                    	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                    	language: "en",
                    	locale: "en-US",   // this variable is provided as a consistent location
                    			   // it is currently only used by 3rd party modules. no MagicMirror code uses this value
                    			   // as we have no usage, we  have no constraints on what this field holds
                    			   // see https://en.wikipedia.org/wiki/Locale_(computer_software) for the possibilities
                    	timeFormat: 24,
                    	units: "metric",
                    		// Base WallberryTheme adds new font, styles, and a rotating background image pulled from Unsplash.com
                    		    module: "WallberryTheme",
                    		    position: "fullscreen_below", // Required Position
                    		      unsplashAccessKey: "YOUR_API_KEY_HERE", // REQUIRED
                    		      collections: "XXXX" // optional - leave empty for a random photo
                    		  // WB-clock adds local time (Optional Module)
                    		    module: "WallberryTheme/WB-clock",
                    		    position: "top_bar", // highly suggest using top_bar position
                    		      //localCityName: "Seattle", // optional
                    		      //otherCities: [
                    		      	//{name: "DC", timezone: "US/Eastern"}, // optional
                    		      	//{name: "Anchorage", timezone: "US/Alaska"} // optional
                    		  // WB-weather adds weather (Optional Module)
                    		    module: "WallberryTheme/WB-weather",
                    		    position: "bottom_bar",  // Highly suggested location
                    		    		// See "Configuration options" for more information.
                    				apiKey: "YOUR_API_KEY_HERE", // REQUIRED
                    				latitude: YOUR_LATITUDE, // REQUIRED
                    				longitude: YOUR_LONGITUDE // REQUIRED
                        			module: 'MMM-BackgroundSlideshow',
                        			position: 'fullscreen_below',
                          				imagePaths: ['/mnt/XXX/'],
                    				recursiveSubDirectories: true,
                    				transitionImages: false,
                          				randomizeImageOrder: true,
                    				showImageInfo:	true,
                    				showProgressBar: false,
                    				imageInfoNoFileExt: true,
                    				showAllImagesBeforeRestart: true,
                    				slideshowSpeed: 600000,
                                		module: 'MMM-auto-refresh',
                                    		// See below for configurable options
                    				refreshInterval: 21600000  //6 hours
                                		module: 'MMM-CountDown',
                    			disabled: true,
                    			position: 'bottom_right',
                                    		event: "SOMEONES Birthday:",
                    				date: "2026-01-01 00:00:00",
                    				daysLabel: " days",
                    				showHours: false,
                        				showMinutes: false,
                        				showSeconds: false
                    		    module: 'MMM-HomeAssistant',
                    			mqttServer: 'mqtt://192.XXX.X.XX',
                    			mqttPort: XXXX,
                    			username: 'XXXXXX',
                    			password: 'XXXXXXXXXXXXXXXXXXXXX',
                    			deviceName: 'XXXMagicMirror',
                    			autodiscoveryTopic: 'homeassistant',
                    			monitorControl: false,
                    			brightnessControl: true,
                    			moduleControl: true,
                            		monitorStatusCommand: 'wlr-randr | awk \'/HDMI-A-1/ {found=1} found && /Enabled:/ {print ($2 == "yes") ? "true" : "false"; exit} END {if(!found) print "false"}\'',
                            		monitorOnCommand: 'wlr-randr --output HDMI-A-1 --on',
                            		monitorOffCommand: 'wlr-randr --output HDMI-A-1 --off',
                    			pm2ProcessName: 'mm',
                    			refreshBrowser: true
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			disabled: true,
                    			position: "top_left"
                    			header: "US Holidays",
                    			//position: "top_left",
                    						symbol: "calendar-check",
                    						url: "https://calendar.google.com/calendar/ical/YOUR_GOOGLE_CAL_URL.ics",
                    						//url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                    			module: "MMM-MonthlyCalendar",
                    			config: { // See "Configuration options" for more information.
                    				mode: "twoWeeks",
                    				firstDayOfWeek:	"monday",
                          			module: "helloworld",
                          			position: "bottom_bar", // This can be any of the regions.
                    			disabled: true,
                            			text: "Happy birthday!",
                    			module: "compliments",
                    			disabled: true,
                    			position: "lower_third"
                    			module: "weather",
                    			disabled: true,
                    				weatherProvider: "openmeteo",
                    				type: "current",
                    				lat: YOUR LATITUDE,
                    				lon: YOUR LONGITUDE
                    			module: "weather",
                    			disabled: true,
                    			header: "Weather Forecast",
                    				type: "forecast",
                    				lat: YOUR LATITUDE,
                    				lon: YOUR LONGITUDE
                    			module: "newsfeed",
                    			disabled: true,
                    				feeds: [
                    						title: "New York Times",
                    						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    P J 2 Replies Last reply Reply Quote 0
                    • P Offline
                      @mrchips83 this is awesome!!! thank you so much!!! Cheers, RIch
                        Junoman @botts85
                        @botts85
                        Not being able to write my own code is always a challenge. But that would be a key feature to sort/detect light and dark based photos (portrait vs landscape too) and take it up a level.
                        My wife is nature and wildlife photographer so we have about 300k+ photos.
                        I actually spent too many hours sorting through photos to find the right ones that worked with my fonts and color layouts.
                        Additionally, I had to choose all portrait size to not mix landscape and ensure they all work perfectly.
                        In the end I chose about 200 photos that worked best with my layout.
                        Guess it’s more a love of labor ;-)
                          Junoman @mrchips83
                          @mrchips83 Thanks for sharing.
                          Interest is peeked again! Think I’m going to dive back into MM.
