    All modules shown on one page after Update to 2.35
    12 Posts 5 Posters 1.6k Views 4 Watching
    • NiggichN Offline
      Niggich
      Hallo Guys,
      my Mirror Dashboard is using 13 pages. Since the last update all the modules are shown at page 1 after a restart. When I select the Page 1 for example everything is shown correct. It’s only after a restart or a refresh of the Page. Maybe somebody have an idea?
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @Niggich
        @Niggich What do you user for the pages? MMM-Carousel or MMM-pages? Do you use a fork?
        I tested the original projects of MMM-Carousel and MMM-pages without any issues.
        NiggichN 1 Reply Last reply Reply Quote 0
        • NiggichN Offline
          Niggich @KristjanESPERANTO
          @KristjanESPERANTO I use the original MMM-pages. Before the update everything was working fine.
          EDIT: I fixed it. I didn’t recognize the default modules folder changed. I have a custom JSON File for the compliments and this file doesn’t move to the new location. I did it by hand and everything is working fine again.
          THX
          plainbrokeP O 2 Replies Last reply Reply Quote 2
          • NiggichN Niggich has marked this topic as solved on
          • plainbrokeP Offline
            plainbroke @Niggich
            @Niggich
            Awesome find and fix. I too use a custom json file in compliments and would never have figured that out…
            • O Offline
              oskisch @Niggich
              THX
              How did you solve this? My MM-pages broke when I updated to the latest version. I only get a single page displayed which refreshes with the same content?
              I get a lot of errors when running the mm.sh startup script
              ./mm.sh
              [2026-04-03 19:46:10.692] [LOG]   [app] Starting MagicMirror: v2.36.0-develop
              [2026-04-03 19:46:10.732] [LOG]   [utils] Loading config ...
              [2026-04-03 19:46:10.757] [INFO]  [utils] Checking config file /home/pi/MagicMirror/config/config.js ...
              [2026-04-03 19:46:11.369] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
              [2026-04-03 19:46:11.373] [INFO]  [utils] Checking modules structure configuration ...
              [2026-04-03 19:46:11.684] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
              [2026-04-03 19:46:11.697] [LOG]   [app] Loading module helpers ...
              [2026-04-03 19:46:11.707] [LOG]   [app] No helper found for module: MMM-pages.
              [2026-04-03 19:46:11.712] [LOG]   [app] No helper found for module: MMM-YrMeteogram.
              [2026-04-03 19:46:11.746] [ERROR] [app] Error when loading MMM-Flights: Cannot find module '@khassel/magicmirror-helper/mm_helper'
              Require stack:
              - /home/pi/MagicMirror/modules/MMM-Flights/node_helper.js
              [2026-04-03 19:46:11.768] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:11.772] [LOG]   [node_helper] Module helper loaded: MMM-HTMLSnippet
              [2026-04-03 19:46:12.022] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:12.032] [LOG]   [node_helper] Module helper loaded: MMM-MoonPhase
              [2026-04-03 19:46:12.085] [LOG]   [app] No helper found for module: MMM-SmartWebDisplay.
              [2026-04-03 19:46:12.113] [LOG]   [app] No helper found for module: alert.
              [2026-04-03 19:46:12.259] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:12.261] [LOG]   [node_helper] Module helper loaded: updatenotification
              [2026-04-03 19:46:12.280] [LOG]   [app] No helper found for module: clock.
              [2026-04-03 19:46:12.312] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:12.326] [LOG]   [node_helper] Module helper loaded: MMM-CrisisInformationSweden
              [2026-04-03 19:46:12.368] [LOG]   [app] No helper found for module: MMM-MagicMover.
              [2026-04-03 19:46:12.456] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:12.458] [LOG]   [node_helper] Module helper loaded: MMM-EUElectricityPrice
              [2026-04-03 19:46:12.998] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:13.000] [LOG]   [node_helper] Module helper loaded: MMM-MarineTraffic
              [2026-04-03 19:46:13.019] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:13.025] [LOG]   [node_helper] Module helper loaded: weather
              [2026-04-03 19:46:13.539] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:13.541] [LOG]   [node_helper] Module helper loaded: MMM-Pinfo
              [2026-04-03 19:46:13.597] [LOG]   [MMM-Soliscloud] onoff module is not installed
              [2026-04-03 19:46:13.599] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:13.601] [LOG]   [node_helper] Module helper loaded: MMM-Soliscloud
              [2026-04-03 19:46:14.516] [LOG]   [node_helper] Initializing new module helper ...
              [2026-04-03 19:46:14.518] [LOG]   [node_helper] Module helper loaded: newsfeed
              [2026-04-03 19:46:14.520] [LOG]   [app] All module helpers loaded.
              [2026-04-03 19:46:14.587] [LOG]   [server] Starting server on port 8080 ...
              [37711:0403/194614.815137:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
              [37711:0403/194614.820115:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
              [37711:0403/194614.820383:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
              pi@Oskars-MM64GB:~ $ [2026-04-03 19:46:16.543] [INFO]  [systeminformation]
              ####  System Information  ####
              - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; virtual: false; MM: v2.36.0-develop
              - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8
              - VERSIONS: electron: 41.1.0; used node: 22.21.1; installed node: 22.21.1; npm: 11.12.1; pm2: 6.0.14
              - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                          WAYLAND_DISPLAY:  wayland-1; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
              - RAM:      total: 905.98 MB; free: 645.31 MB; used: 260.67 MB
              - OTHERS:   uptime: 58 minutes; timeZone: Europe/Stockholm
              KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                KristjanESPERANTO Module Developer @oskisch
                @oskisch said:
                • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; virtual: false; MM: v2.36.0-develop
                Why are you on the develop branch?
                  Try node --run start:x11
                  • O Offline
                    oskisch @KristjanESPERANTO
                    @KristjanESPERANTO
                    I tried that to fix the problem after the update.
                    The mirror starts up, only displays one page for some reson?
                      @oskisch Are you still on the develop branch? Are there still errors in the console?
                        sdetweil @KristjanESPERANTO
                        @KristjanESPERANTO browser developer window console
                        • O Offline
                          That’s just because I used SSH to copy the log, it works fine on the local machine.
                            sdetweil @oskisch
                            @oskisch we need the browser log,
                            Can’t get without keyboard
