    MMM-traffic - used 12 hour to get it work but can not....
    6 Posts 2 Posters 3.4k Views 2 Watching
    • I
      ironman_DK
      Hi
      Im totally new into this MM2 - I have tried to get this MMM trafic module to work, I have so far used 12 hour on this project :-/ so can anyone help mee?
      I have installed the MMM-traffic module and have add. following to Config.js :
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
      	language: 'da',
      	timeFormat: 24,
      	units: 'metric',
      			module: 'alert',
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'Kalender',
      			position: 'top_left',
      						symbol: 'home',
      						url: 'XXXXXXXX'
      						symbol: 'home',
      						url: 'XXXXXXXXX'
      						symbol: 'home',
      						url: 'XXXXXXXXXX'
      						symbol: 'home',
      						url: 'XXXXXXXXXX'
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'currentweather',
      			position: 'lower_right',
      				locationID: '2618425',  //ID from http://www.openweathermap.org
      				appid: 'XXXXXXXXXXXX'
      			module: 'weatherforecast',
      			position: 'top_right',
      			header: 'Weather Forecast',
      				appid: 'XXXXXXXXXXX'
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "Ekstra Bladet Nyheder",
      						url: "http://ekstrabladet.dk/rss2/?mode=normal&submode=nyheder"
      				showSourceTitle: true,
      				showPublishDate: true
      	module: 'MMM-Traffic',
      	position: 'middle_center',
      	classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
      		api_key: 'XXXXXXXXXXXX',
      		mode: 'driving',
      		origin: '4 Pennsylvania Plaza, New York, NY 10001',
      		destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073',
      		arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
      		route_name: 'Home to Work',
      		changeColor: true,
      		showGreen: false,
      		limitYellow: 5, //Greater than 5% of journey time due to traffic
      		limitRed: 20, //Greater than 20% of journey time due to traffic
      		traffic_model: 'pessimistic',
      		interval: 120000, //2 minutes
      		showWeekend: false,
      		allTime: false
      After I have copy/paste the MMM-traffic module into Config.JS I only got a black screen, If I remove the MMM-Traffic in config.JS everything is fine, and I got my three calendars weather and news - what can be wrong ?
      is the error in config.JS or MMM-Traffic module ?
      best regards
      Michael
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @ironman_DK
        @ironman_DK the config for traffic works for me. Did you install the module in the correct folder ~/MagicMirror/modules/MMM-Traffic? Did you install the dependencies?
        • I
          ironman_DK @strawberry 3.141
          @strawberry-3.141 said in MMM-traffic - used 12 hour to get it work but can not....:
          dependencies
          the Module is installed correct, what is dependencies, and what do I do ? I really need your help in this matter…
          is dependencies something there should be in config.js or ?
          Best regards
          Michael
          • strawberry 3.141S
            @ironman_DK did you run npm install in ~/MagicMirror/modules/MMM-Traffic
            • I
              @strawberry-3.141 yes I did the installation in the right modules etc…
              • strawberry 3.141S
                @ironman_DK problem solved. Somehow he modified the module directory name to lowercase and the system couldn’t find the module.
