    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 41.2k Views 14 Watching
    • slametpsS Offline
      slametps @aishaamila
      @aishaamila said in MMM-PrayerTime:
      @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
      What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
      regards,
      Slamet PS
      • slametpsS Offline
        slametps @slametps
        @slametps said in MMM-PrayerTime:
        @aishaamila
        timezone: "Asia/Kuala_Lumpur",
        As described in http://php.net/manual/en/timezones.asia.php.
        regards,
        Slamet PS
        A 2 Replies Last reply Reply Quote 0
          aishaamila @slametps
          @slametps /usr/bin/omxplayer -o local modules/MMM-PrayerTime/res/adzan.mp3
          I use this command to play the adzan and it worked, but during the time it didnt played. That’s why I am confused.
            @slametps okay I will try this first thankyou so much
              @slametps it still not working?is there any problem with time interval?
              • G Offline
                govabm
                Salam Aleykum,
                i need help for the config.
                thats my File:
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "de",
                	timeFormat: 24,
                	units: "metric",
                		module:'MMM-PrayerTime',
                		position: 'top_right',
                			apiVersion: "1.0",
                			lat: 55.841727,
                			lon: 13.303381,
                			timezone: 'Europe/Berlin',
                			timeFormat: 24,
                			method: 3,
                			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                			notDisplayed: ['midnight', 'sunset'],
                			useUpdateInterval: true,
                			updateInterval: 86400 * 1000,
                			animationSpeed: 2.5 * 1000,
                			language: "en",
                			showAdzanAlert: true,
                			alertTimer: 15000
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_right"
                			header: "Ferien Deutschland",
                						symbol: "calendar-check-o ",
                						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                			module: "compliments",
                			position: "bottom_bar"
                			module: "currentweather",
                				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                				appid: "YOUR_OPENWEATHER_API_KEY"
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                • G Offline
                  govabm
                  sorry have a foult this is the file:
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "de",
                  	timeFormat: 24,
                  	units: "metric",
                  			apiVersion: "1.0",
                  			lat: 55.841727,
                  			lon: 13.303381,
                  			timeFormat: 24,
                  			method: 3,
                  			language: "en",
                  			alertTimer: 15000
                  			module: "alert",
                  			position: "top_bar"
                  			module: "clock",
                  			module: "newsfeed",
                  				feeds: [
                  the mirror works but i dont see the Modul
                  • G Offline
                    govabm
                    it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
                    Barakallhufeek
                    • T Offline
                      Tito
                      is it possible to add iqama times?
                        berlink36
                        Selamun Aleykum,
                        i want to set my own calculation method, how can i do this for Berlin
                        the calculation is very close to the method:
                        13=Diyanet İşleri Başkanlığı, Turkey
                        need some help,
                        module: “MMM-PrayerTime”,
                        position: “middle_center”, // This can be any of the regions. Best result is in the top_left/top_right.
                                                    apiVersion: "1.0", // please, leave unchanged. reserved for future use.
                                                    lat: "52.5069312", // latitude of your position (city)
                                                    lon: "13.1445453", // longitude of your position (city)
                                                    timezone: "Europe/Berlin", // please refer to http://php.net/manual/en/timezones.php
                                                    timeFormat: "24",
                                                    method: "13",
                                                    playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
                                                    notDisplayed: ["midnight", "sunset"],
                                                    useUpdateInterval: "true",
                                                    updateInterval: "86400 * 1000", // How often do you want to fetch new praying time? (milliseconds)
                                                    animationSpeed: "2.5 * 1000", // Speed of the update animation. (milliseconds)
                                                    language: "en",
                                                    showAdzanAlert: "true",
                                                    showTomorrow: "true",
                                                    alertTimer: "15000",
                        • 6
                        • 5 / 6
