    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 55.9k Views 14 Watching
    • slametpsS
      slametps @danialothman
      @danialothman said in MMM-PrayerTime:
      @zzaidi148 @slametps
      does the MMM-PrayerTime still work??
      I am trying to set it up but fail to get anything.
      yeah, of course. mine is running. if you got trouble running this module, try install async module.
      npm install async
      regards,
      Slamet PS
      D 1 Reply Last reply
        danialothman @slametps
        @slametps my apologies,
        yes it does work. Thank you for building this.
        there were some missing commas in your module page, which I overlooked.
        In case anyone from Brunei, you can use the below:
        		module: "MMM-PrayerTime",
        			apiVersion: "1.0",
        			lat: 4.5353,
        			lon: 114.7277,
        			timezone: "Asia/Brunei",
        			timeFormat: 24,
        			method: 3,
        			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
        			notDisplayed: ['midnight', 'sunset'],
        			useUpdateInterval: true,
        			updateInterval: 86400 * 1000,
        			animationSpeed: 2.5 * 1000,
        			language: "en",
        			showAdzanAlert: true,
        			alertTimer: 15000
        slametpsS 1 Reply Last reply
        • slametpsS
          @danialothman thx for correction. I fixed the info in the github.
          @zzaidi148 said in MMM-PrayerTime:
          @slametps Thank you so much! How do I do that?
          go to MMM-PrayerTime folder and run:
          git pull
          regards,
          Slamet PS
          • A
            aishaamila @noorm91
            @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
            A 1 Reply Last reply
            • A
              aishaamila @aishaamila
              @aishaamila Or anyone who knows it?
              • slametpsS
                slametps @aishaamila
                @aishaamila said in MMM-PrayerTime:
                What is your MM hardware and config?
                regards,
                Slamet PS
                • slametpsS
                  slametps @slametps
                  Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                  regards,
                  Slamet PS
                  • A
                    aishaamila @slametps
                    @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                    • slametpsS
                      @aishaamila can you post your config?
                      regards,
                      Slamet PS
                      A 2 Replies Last reply
                      • A
                        @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
                        • A
                          @slametps do i need to change something?
                          			apiVersion: "1.0",
                          			lat: 2.1484105,
                          			lon: 102.7285677,
                          			timezone: "Asia/Kuala Lumpur",
                          			timeFormat: 24,
                          			method: 4,
                          			alertTimer: 15000
                          • slametpsS
                            @aishaamila
                            timezone: "Asia/Kuala_Lumpur",
                            regards,
                            Slamet PS
                            • slametpsS
                              What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
                              regards,
                              Slamet PS
                              • slametpsS
                                slametps @slametps
                                @slametps said in MMM-PrayerTime:
                                @aishaamila
                                As described in http://php.net/manual/en/timezones.asia.php.
                                regards,
                                Slamet PS
                                • A
                                  @slametps /usr/bin/omxplayer -o local modules/MMM-PrayerTime/res/adzan.mp3
                                  I use this command to play the adzan and it worked, but during the time it didnt played. That’s why I am confused.
                                  • A
                                    @slametps okay I will try this first thankyou so much
                                    • A
                                      @slametps it still not working?is there any problem with time interval?
                                      • G
                                        govabm
                                        Salam Aleykum,
                                        i need help for the config.
                                        thats my File:
                                        /* Magic Mirror Config Sample
                                         * MIT Licensed.
                                        var config = {
                                        	port: 8080,
                                        	language: "de",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        		module:'MMM-PrayerTime',
                                        		position: 'top_right',
                                        			apiVersion: "1.0",
                                        			lat: 55.841727,
                                        			lon: 13.303381,
                                        			timezone: 'Europe/Berlin',
                                        			timeFormat: 24,
                                        			method: 3,
                                        			language: "en",
                                        			alertTimer: 15000
                                        			module: "alert",
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			position: "top_right"
                                        			header: "Ferien Deutschland",
                                        						symbol: "calendar-check-o ",
                                        			module: "compliments",
                                        			position: "bottom_bar"
                                        			module: "currentweather",
                                        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        			module: "weatherforecast",
                                        			header: "Weather Forecast",
                                        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        			module: "newsfeed",
                                        			position: "bottom_bar",
                                        				feeds: [
                                        						title: "New York Times",
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                        • G
                                          govabm
                                          sorry have a foult this is the file:
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "de",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          			apiVersion: "1.0",
                                          			lat: 55.841727,
                                          			lon: 13.303381,
                                          			timeFormat: 24,
                                          			method: 3,
                                          			language: "en",
                                          			alertTimer: 15000
                                          			module: "alert",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			module: "newsfeed",
                                          				feeds: [
                                          the mirror works but i dont see the Modul
                                          • G
                                            govabm
                                            it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
                                            Barakallhufeek
                                            • 2 / 3
