    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 55.6k Views 14 Watching
    • slametpsS
      slametps @noorm91
      @noorm91 said in MMM-PrayerTime:
                          module: 'MMM-PrayerTime',
                          position: 'top_right',
                                  apiVersion: '1.0',
                                  lat: 55.841727,
                                  lon: 13.303381,
                                  timezone: 'Europe/Stockholm',
                                  method: 3,
                                  playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                                  notDisplayed: ['midnight', 'sunset'],
                                  useUpdateInterval: true,
                                  updateInterval: 86400 * 1000,
                                  animationSpeed: 2.5 * 1000,
                                  language: config.language,
                                  showAdzanAlert: true,
                                  alertTimer: 15000
      Salam, changed it but still not working :( lon/lat: is ok? how about language: ?
      Actually this is my first module I’m trying to get working, pretty new to MM2 so maybe I need to change somewhere else too.
      The module is under here;
      pi@raspberrypi:~/MagicMirror/modules $ ls
      default MMM-PrayerTime node_modules README.md
      pi@raspberrypi:~/MagicMirror/modules/MMM-PrayerTime $ ls
      LICENSE MMM-PrayerTime.css MMM-PrayerTime.js node_helper.js README.md res screenshot2.jpg screenshot-alert.png screenshot.png translations
      You may simply remove language: config.language line, and see if this work. It tells MMM-PrayerTime module to use MM global language config. If not work, please use 'en' for language entry.
      regards,
      Slamet PS
      • N
        noorm91
        Alhamdulillah almost there, the module shows up in top_right with this conf, but it just says " Loading … " any known reason?
                                    apiVersion: '1.0',
                                    lat: 55.841727,
                                    lon: 13.303381,
                                    timezone: "Europe/Stockholm",
                                    method: 3,
                                    language: 'en',
                                    alertTimer: 15000
        slametpsS 1 Reply Last reply
        • slametpsS
          slametps @noorm91
          @noorm91 can you post the pm2/mm log?
          regards,
          Slamet PS
          Z 1 Reply Last reply
          • Z
            zzaidi148 @slametps
            @slametps Alhamdulillah I got it work by taking out the language line. It works well now. I was wondering if there was any way I could take out the Imsak times from the module and to have the times be in a 12 hour format. Also, how do I make sure that it plays the athan? Thanks for all the help!
            • slametpsS
              slametps @zzaidi148
              @zzaidi148 said in MMM-PrayerTime:
              You can remove Imsak from the schedule by adding config notDisplayed: ['midnight', 'sunset', 'imsak']. Currently, support 24-hour format only.
              Your MM has speaker? If yes, you can check type following command in console:
              /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3
              It will play adzan.mp3.
              regards,
              Slamet PS
              • N
                noorm91
                I will try get the log when I’m home, just a simple question, does this work with Midori browser, because that is the one I’m using on Rpi 1 model b…I entered my Rpi IP address in chrome from my computer and then I saw the module perfectly.
                slametpsS A 2 Replies Last reply
                • slametpsS
                  slametps @noorm91
                  Sorry, I haven’t test it on midori browser.
                  regards,
                  Slamet PS
                  • Z
                    zzaidi148
                    Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
                    • slametpsS
                      slametps @zzaidi148
                      You should modify the module according to each API provider data. Why should be 12-hour format?
                      regards,
                      Slamet PS
                      • Z
                        zzaidi148 @slametps
                        @slametps 12hour format would be easier for people in America to read.
                        • slametpsS
                          slametps @zzaidi148
                          Sorry for late response.
                          I’ll see what I can do tonight. I’ll inform you if 12-hour format is supported.
                          regards,
                          Slamet PS
                          • slametpsS
                            slametps @slametps
                            @slametps said in MMM-PrayerTime:
                            I have added 12-hours time-format support. Please update your clone.
                            regards,
                            Slamet PS
                            • Z
                              zzaidi148 @slametps
                              @slametps Thank you so much! How do I do that?
                              D 1 Reply Last reply
                                danialothman @zzaidi148
                                @zzaidi148 @slametps
                                does the MMM-PrayerTime still work??
                                I am trying to set it up but fail to get anything.
                                • Krato5K
                                  Krato5
                                  what kind of issue that you get ?
                                  • slametpsS
                                    slametps @danialothman
                                    @danialothman said in MMM-PrayerTime:
                                    yeah, of course. mine is running. if you got trouble running this module, try install async module.
                                    npm install async
                                    regards,
                                    Slamet PS
                                      danialothman @slametps
                                      @slametps my apologies,
                                      yes it does work. Thank you for building this.
                                      there were some missing commas in your module page, which I overlooked.
                                      In case anyone from Brunei, you can use the below:
                                      		module: "MMM-PrayerTime",
                                      			apiVersion: "1.0",
                                      			lat: 4.5353,
                                      			lon: 114.7277,
                                      			timezone: "Asia/Brunei",
                                      			timeFormat: 24,
                                      			method: 3,
                                      			language: "en",
                                      			alertTimer: 15000
                                      • slametpsS
                                        @danialothman thx for correction. I fixed the info in the github.
                                        go to MMM-PrayerTime folder and run:
                                        git pull
                                        regards,
                                        Slamet PS
                                        • A
                                          aishaamila @noorm91
                                          @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
                                          A 1 Reply Last reply
                                          • A
                                            aishaamila @aishaamila
                                            @aishaamila Or anyone who knows it?
                                            • 2 / 3
