    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 55.5k Views 14 Watching
    • slametpsS
      slametps @zzaidi148
      @zzaidi148 said in MMM-PrayerTime:
      Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
      You should modify the module according to each API provider data. Why should be 12-hour format?
      regards,
      Slamet PS
      Z 1 Reply Last reply Reply Quote 0
      • Z
        zzaidi148 @slametps
        @slametps 12hour format would be easier for people in America to read.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS
          slametps @zzaidi148
          Sorry for late response.
          I’ll see what I can do tonight. I’ll inform you if 12-hour format is supported.
          regards,
          Slamet PS
          • slametpsS
            slametps @slametps
            @slametps said in MMM-PrayerTime:
            I have added 12-hours time-format support. Please update your clone.
            regards,
            Slamet PS
            Z 1 Reply Last reply Reply Quote 1
            • Z
              zzaidi148 @slametps
              @slametps Thank you so much! How do I do that?
                danialothman @zzaidi148
                @zzaidi148 @slametps
                does the MMM-PrayerTime still work??
                I am trying to set it up but fail to get anything.
                • Krato5K
                  Krato5
                  what kind of issue that you get ?
                  • slametpsS
                    slametps @danialothman
                    @danialothman said in MMM-PrayerTime:
                    yeah, of course. mine is running. if you got trouble running this module, try install async module.
                    npm install async
                    regards,
                    Slamet PS
                      danialothman @slametps
                      @slametps my apologies,
                      yes it does work. Thank you for building this.
                      there were some missing commas in your module page, which I overlooked.
                      In case anyone from Brunei, you can use the below:
                      		module: "MMM-PrayerTime",
                      			apiVersion: "1.0",
                      			lat: 4.5353,
                      			lon: 114.7277,
                      			timezone: "Asia/Brunei",
                      			timeFormat: 24,
                      			method: 3,
                      			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                      			notDisplayed: ['midnight', 'sunset'],
                      			useUpdateInterval: true,
                      			updateInterval: 86400 * 1000,
                      			animationSpeed: 2.5 * 1000,
                      			language: "en",
                      			showAdzanAlert: true,
                      			alertTimer: 15000
                      • slametpsS
                        @danialothman thx for correction. I fixed the info in the github.
                        go to MMM-PrayerTime folder and run:
                        git pull
                        regards,
                        Slamet PS
                        • A
                          aishaamila @noorm91
                          @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
                          • A
                            aishaamila @aishaamila
                            @aishaamila Or anyone who knows it?
                            • slametpsS
                              slametps @aishaamila
                              @aishaamila said in MMM-PrayerTime:
                              What is your MM hardware and config?
                              regards,
                              Slamet PS
                              • slametpsS
                                slametps @slametps
                                Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                                regards,
                                Slamet PS
                                • A
                                  aishaamila @slametps
                                  @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                                  • slametpsS
                                    @aishaamila can you post your config?
                                    regards,
                                    Slamet PS
                                    A 2 Replies Last reply Reply Quote 0
                                    • A
                                      @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
                                      • A
                                        @slametps do i need to change something?
                                        			apiVersion: "1.0",
                                        			lat: 2.1484105,
                                        			lon: 102.7285677,
                                        			timezone: "Asia/Kuala Lumpur",
                                        			timeFormat: 24,
                                        			method: 4,
                                        			alertTimer: 15000
                                        • slametpsS
                                          @aishaamila
                                          timezone: "Asia/Kuala_Lumpur",
                                          regards,
                                          Slamet PS
                                          • slametpsS
                                            What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
                                            regards,
                                            Slamet PS
                                            • 2 / 3
