    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 55.6k Views 14 Watching
    • Z
      zzaidi148
      Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
      slametpsS 1 Reply Last reply
      • slametpsS
        slametps @zzaidi148
        @zzaidi148 said in MMM-PrayerTime:
        You should modify the module according to each API provider data. Why should be 12-hour format?
        regards,
        Slamet PS
        Z 1 Reply Last reply
        • Z
          zzaidi148 @slametps
          @slametps 12hour format would be easier for people in America to read.
          • slametpsS
            slametps @zzaidi148
            Sorry for late response.
            I’ll see what I can do tonight. I’ll inform you if 12-hour format is supported.
            regards,
            Slamet PS
            • slametpsS
              slametps @slametps
              @slametps said in MMM-PrayerTime:
              I have added 12-hours time-format support. Please update your clone.
              regards,
              Slamet PS
              • Z
                zzaidi148 @slametps
                @slametps Thank you so much! How do I do that?
                D 1 Reply Last reply
                  danialothman @zzaidi148
                  @zzaidi148 @slametps
                  does the MMM-PrayerTime still work??
                  I am trying to set it up but fail to get anything.
                  • Krato5K
                    Krato5
                    what kind of issue that you get ?
                    • slametpsS
                      slametps @danialothman
                      @danialothman said in MMM-PrayerTime:
                      yeah, of course. mine is running. if you got trouble running this module, try install async module.
                      npm install async
                      regards,
                      Slamet PS
                        danialothman @slametps
                        @slametps my apologies,
                        yes it does work. Thank you for building this.
                        there were some missing commas in your module page, which I overlooked.
                        In case anyone from Brunei, you can use the below:
                        		module: "MMM-PrayerTime",
                        			apiVersion: "1.0",
                        			lat: 4.5353,
                        			lon: 114.7277,
                        			timezone: "Asia/Brunei",
                        			timeFormat: 24,
                        			method: 3,
                        			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                        			notDisplayed: ['midnight', 'sunset'],
                        			useUpdateInterval: true,
                        			updateInterval: 86400 * 1000,
                        			animationSpeed: 2.5 * 1000,
                        			language: "en",
                        			showAdzanAlert: true,
                        			alertTimer: 15000
                        • slametpsS
                          @danialothman thx for correction. I fixed the info in the github.
                          go to MMM-PrayerTime folder and run:
                          git pull
                          regards,
                          Slamet PS
                          • A
                            aishaamila @noorm91
                            @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
                            A 1 Reply Last reply
                            • A
                              aishaamila @aishaamila
                              @aishaamila Or anyone who knows it?
                              • slametpsS
                                slametps @aishaamila
                                @aishaamila said in MMM-PrayerTime:
                                What is your MM hardware and config?
                                regards,
                                Slamet PS
                                • slametpsS
                                  slametps @slametps
                                  Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                                  regards,
                                  Slamet PS
                                  • A
                                    aishaamila @slametps
                                    @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                                    • slametpsS
                                      @aishaamila can you post your config?
                                      regards,
                                      Slamet PS
                                      A 2 Replies Last reply
                                      • A
                                        @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
                                        • A
                                          @slametps do i need to change something?
                                          			apiVersion: "1.0",
                                          			lat: 2.1484105,
                                          			lon: 102.7285677,
                                          			timezone: "Asia/Kuala Lumpur",
                                          			timeFormat: 24,
                                          			method: 4,
                                          			alertTimer: 15000
                                          • slametpsS
                                            @aishaamila
                                            timezone: "Asia/Kuala_Lumpur",
                                            regards,
                                            Slamet PS
                                            • 2 / 3
