    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 54.2k Views 14 Watching
    • Z Offline
      zzaidi148 @slametps
      @slametps Alhamdulillah I got it work by taking out the language line. It works well now. I was wondering if there was any way I could take out the Imsak times from the module and to have the times be in a 12 hour format. Also, how do I make sure that it plays the athan? Thanks for all the help!
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @zzaidi148
        @zzaidi148 said in MMM-PrayerTime:
        You can remove Imsak from the schedule by adding config notDisplayed: ['midnight', 'sunset', 'imsak']. Currently, support 24-hour format only.
        Your MM has speaker? If yes, you can check type following command in console:
        /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3
        It will play adzan.mp3.
        regards,
        Slamet PS
        • N Offline
          noorm91
          I will try get the log when I’m home, just a simple question, does this work with Midori browser, because that is the one I’m using on Rpi 1 model b…I entered my Rpi IP address in chrome from my computer and then I saw the module perfectly.
          slametpsS A 2 Replies Last reply Reply Quote 0
          • slametpsS Offline
            slametps @noorm91
            @noorm91 said in MMM-PrayerTime:
            Sorry, I haven’t test it on midori browser.
            regards,
            Slamet PS
            • Z Offline
              zzaidi148
              Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
              • slametpsS Offline
                slametps @zzaidi148
                You should modify the module according to each API provider data. Why should be 12-hour format?
                regards,
                Slamet PS
                Z 1 Reply Last reply Reply Quote 0
                • Z Offline
                  zzaidi148 @slametps
                  @slametps 12hour format would be easier for people in America to read.
                  • slametpsS Offline
                    slametps @zzaidi148
                    Sorry for late response.
                    I’ll see what I can do tonight. I’ll inform you if 12-hour format is supported.
                    regards,
                    Slamet PS
                    • slametpsS Offline
                      slametps @slametps
                      @slametps said in MMM-PrayerTime:
                      I have added 12-hours time-format support. Please update your clone.
                      regards,
                      Slamet PS
                      Z 1 Reply Last reply Reply Quote 1
                      • Z Offline
                        zzaidi148 @slametps
                        @slametps Thank you so much! How do I do that?
                          danialothman @zzaidi148
                          @zzaidi148 @slametps
                          does the MMM-PrayerTime still work??
                          I am trying to set it up but fail to get anything.
                          • Krato5K Offline
                            Krato5
                            what kind of issue that you get ?
                            • slametpsS Offline
                              slametps @danialothman
                              @danialothman said in MMM-PrayerTime:
                              yeah, of course. mine is running. if you got trouble running this module, try install async module.
                              npm install async
                              regards,
                              Slamet PS
                                danialothman @slametps
                                @slametps my apologies,
                                yes it does work. Thank you for building this.
                                there were some missing commas in your module page, which I overlooked.
                                In case anyone from Brunei, you can use the below:
                                		module: "MMM-PrayerTime",
                                			apiVersion: "1.0",
                                			lat: 4.5353,
                                			lon: 114.7277,
                                			timezone: "Asia/Brunei",
                                			timeFormat: 24,
                                			method: 3,
                                			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                                			notDisplayed: ['midnight', 'sunset'],
                                			useUpdateInterval: true,
                                			updateInterval: 86400 * 1000,
                                			animationSpeed: 2.5 * 1000,
                                			language: "en",
                                			showAdzanAlert: true,
                                			alertTimer: 15000
                                • slametpsS Offline
                                  @danialothman thx for correction. I fixed the info in the github.
                                  go to MMM-PrayerTime folder and run:
                                  git pull
                                  regards,
                                  Slamet PS
                                    aishaamila @noorm91
                                    @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
                                      aishaamila @aishaamila
                                      @aishaamila Or anyone who knows it?
                                      • slametpsS Offline
                                        slametps @aishaamila
                                        @aishaamila said in MMM-PrayerTime:
                                        What is your MM hardware and config?
                                        regards,
                                        Slamet PS
                                        • slametpsS Offline
                                          slametps @slametps
                                          Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                                          regards,
                                          Slamet PS
                                            aishaamila @slametps
                                            @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                                            • 2 / 3
