    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 54.9k Views 14 Watching
    • N Offline
      noorm91
      I will try get the log when I’m home, just a simple question, does this work with Midori browser, because that is the one I’m using on Rpi 1 model b…I entered my Rpi IP address in chrome from my computer and then I saw the module perfectly.
      slametpsS A 2 Replies Last reply Reply Quote 0
      • slametpsS Offline
        slametps @noorm91
        @noorm91 said in MMM-PrayerTime:
        Sorry, I haven’t test it on midori browser.
        regards,
        Slamet PS
        • Z Offline
          zzaidi148
          Is it possible to use another api service like islamic finder or salah times api so it would allow for 12-hour format? Thank You
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS Offline
            slametps @zzaidi148
            @zzaidi148 said in MMM-PrayerTime:
            You should modify the module according to each API provider data. Why should be 12-hour format?
            regards,
            Slamet PS
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              zzaidi148 @slametps
              @slametps 12hour format would be easier for people in America to read.
              • slametpsS Offline
                slametps @zzaidi148
                Sorry for late response.
                I’ll see what I can do tonight. I’ll inform you if 12-hour format is supported.
                regards,
                Slamet PS
                • slametpsS Offline
                  slametps @slametps
                  @slametps said in MMM-PrayerTime:
                  I have added 12-hours time-format support. Please update your clone.
                  regards,
                  Slamet PS
                  Z 1 Reply Last reply Reply Quote 1
                  • Z Offline
                    zzaidi148 @slametps
                    @slametps Thank you so much! How do I do that?
                      danialothman @zzaidi148
                      @zzaidi148 @slametps
                      does the MMM-PrayerTime still work??
                      I am trying to set it up but fail to get anything.
                      • Krato5K Offline
                        Krato5
                        what kind of issue that you get ?
                        • slametpsS Offline
                          slametps @danialothman
                          @danialothman said in MMM-PrayerTime:
                          yeah, of course. mine is running. if you got trouble running this module, try install async module.
                          npm install async
                          regards,
                          Slamet PS
                            danialothman @slametps
                            @slametps my apologies,
                            yes it does work. Thank you for building this.
                            there were some missing commas in your module page, which I overlooked.
                            In case anyone from Brunei, you can use the below:
                            		module: "MMM-PrayerTime",
                            			apiVersion: "1.0",
                            			lat: 4.5353,
                            			lon: 114.7277,
                            			timezone: "Asia/Brunei",
                            			timeFormat: 24,
                            			method: 3,
                            			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                            			notDisplayed: ['midnight', 'sunset'],
                            			useUpdateInterval: true,
                            			updateInterval: 86400 * 1000,
                            			animationSpeed: 2.5 * 1000,
                            			language: "en",
                            			showAdzanAlert: true,
                            			alertTimer: 15000
                            • slametpsS Offline
                              @danialothman thx for correction. I fixed the info in the github.
                              go to MMM-PrayerTime folder and run:
                              git pull
                              regards,
                              Slamet PS
                                aishaamila @noorm91
                                @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
                                  aishaamila @aishaamila
                                  @aishaamila Or anyone who knows it?
                                  • slametpsS Offline
                                    slametps @aishaamila
                                    @aishaamila said in MMM-PrayerTime:
                                    What is your MM hardware and config?
                                    regards,
                                    Slamet PS
                                    • slametpsS Offline
                                      slametps @slametps
                                      Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                                      regards,
                                      Slamet PS
                                        aishaamila @slametps
                                        @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                                        • slametpsS Offline
                                          @aishaamila can you post your config?
                                          regards,
                                          Slamet PS
                                            @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
                                            • 2 / 3
