    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 54.7k Views 14 Watching
      danialothman @slametps
      @slametps my apologies,
      yes it does work. Thank you for building this.
      there were some missing commas in your module page, which I overlooked.
      In case anyone from Brunei, you can use the below:
      		module: "MMM-PrayerTime",
      			apiVersion: "1.0",
      			lat: 4.5353,
      			lon: 114.7277,
      			timezone: "Asia/Brunei",
      			timeFormat: 24,
      			method: 3,
      			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
      			notDisplayed: ['midnight', 'sunset'],
      			useUpdateInterval: true,
      			updateInterval: 86400 * 1000,
      			animationSpeed: 2.5 * 1000,
      			language: "en",
      			showAdzanAlert: true,
      			alertTimer: 15000
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @danialothman
        @danialothman thx for correction. I fixed the info in the github.
        @zzaidi148 said in MMM-PrayerTime:
        @slametps Thank you so much! How do I do that?
        go to MMM-PrayerTime folder and run:
        git pull
        regards,
        Slamet PS
          aishaamila @noorm91
          @noorm91 Hello, do you know why during prayer time, azan is not playing? Is there anything i need to add ?
            aishaamila @aishaamila
            @aishaamila Or anyone who knows it?
            • slametpsS Offline
              slametps @aishaamila
              @aishaamila said in MMM-PrayerTime:
              What is your MM hardware and config?
              regards,
              Slamet PS
              • slametpsS Offline
                slametps @slametps
                Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
                regards,
                Slamet PS
                  aishaamila @slametps
                  @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
                  • slametpsS Offline
                    @aishaamila can you post your config?
                    regards,
                    Slamet PS
                    A 2 Replies Last reply Reply Quote 0
                      @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
                        @slametps do i need to change something?
                        			apiVersion: "1.0",
                        			lat: 2.1484105,
                        			lon: 102.7285677,
                        			timezone: "Asia/Kuala Lumpur",
                        			timeFormat: 24,
                        			method: 4,
                        			alertTimer: 15000
                        • slametpsS Offline
                          @aishaamila
                          timezone: "Asia/Kuala_Lumpur",
                          regards,
                          Slamet PS
                          • slametpsS Offline
                            What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
                            regards,
                            Slamet PS
                            • slametpsS Offline
                              slametps @slametps
                              @slametps said in MMM-PrayerTime:
                              @aishaamila
                              As described in http://php.net/manual/en/timezones.asia.php.
                              regards,
                              Slamet PS
                                @slametps /usr/bin/omxplayer -o local modules/MMM-PrayerTime/res/adzan.mp3
                                I use this command to play the adzan and it worked, but during the time it didnt played. That’s why I am confused.
                                  @slametps okay I will try this first thankyou so much
                                    @slametps it still not working?is there any problem with time interval?
                                    • G Offline
                                      govabm
                                      Salam Aleykum,
                                      i need help for the config.
                                      thats my File:
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	port: 8080,
                                      	language: "de",
                                      	timeFormat: 24,
                                      	units: "metric",
                                      		module:'MMM-PrayerTime',
                                      		position: 'top_right',
                                      			apiVersion: "1.0",
                                      			lat: 55.841727,
                                      			lon: 13.303381,
                                      			timezone: 'Europe/Berlin',
                                      			timeFormat: 24,
                                      			method: 3,
                                      			language: "en",
                                      			alertTimer: 15000
                                      			module: "alert",
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			module: "clock",
                                      			position: "top_right"
                                      			header: "Ferien Deutschland",
                                      						symbol: "calendar-check-o ",
                                      			module: "compliments",
                                      			position: "bottom_bar"
                                      			module: "currentweather",
                                      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      			module: "weatherforecast",
                                      			header: "Weather Forecast",
                                      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      			module: "newsfeed",
                                      			position: "bottom_bar",
                                      				feeds: [
                                      						title: "New York Times",
                                      				showSourceTitle: true,
                                      				showPublishDate: true
                                      • G Offline
                                        govabm
                                        sorry have a foult this is the file:
                                         * MIT Licensed.
                                        var config = {
                                        	port: 8080,
                                        	language: "de",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        			apiVersion: "1.0",
                                        			lat: 55.841727,
                                        			lon: 13.303381,
                                        			timeFormat: 24,
                                        			method: 3,
                                        			language: "en",
                                        			alertTimer: 15000
                                        			module: "alert",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			module: "newsfeed",
                                        				feeds: [
                                        the mirror works but i dont see the Modul
                                        • G Offline
                                          govabm
                                          it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
                                          Barakallhufeek
                                          • T Offline
                                            Tito
                                            is it possible to add iqama times?
                                            • 2 / 3
