    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 56.0k Views 14 Watching
    • A
      aishaamila @slametps
      @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
      slametpsS 1 Reply Last reply
      • A
        @slametps do i need to change something?
        		module: "MMM-PrayerTime",
        			apiVersion: "1.0",
        			lat: 2.1484105,
        			lon: 102.7285677,
        			timezone: "Asia/Kuala Lumpur",
        			timeFormat: 24,
        			method: 4,
        			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
        			notDisplayed: ['midnight', 'sunset'],
        			useUpdateInterval: true,
        			updateInterval: 86400 * 1000,
        			animationSpeed: 2.5 * 1000,
        			showAdzanAlert: true,
        			alertTimer: 15000
        • slametpsS
          slametps @aishaamila
          @aishaamila
          timezone: "Asia/Kuala_Lumpur",
          regards,
          Slamet PS
          • slametpsS
            @aishaamila said in MMM-PrayerTime:
            What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
            regards,
            Slamet PS
            A 1 Reply Last reply
            • slametpsS
              slametps @slametps
              @slametps said in MMM-PrayerTime:
              @aishaamila
              As described in http://php.net/manual/en/timezones.asia.php.
              regards,
              Slamet PS
              A 2 Replies Last reply
              • A
                @slametps /usr/bin/omxplayer -o local modules/MMM-PrayerTime/res/adzan.mp3
                I use this command to play the adzan and it worked, but during the time it didnt played. That’s why I am confused.
                • A
                  @slametps okay I will try this first thankyou so much
                  • A
                    @slametps it still not working?is there any problem with time interval?
                    • G
                      govabm
                      Salam Aleykum,
                      i need help for the config.
                      thats my File:
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "de",
                      	timeFormat: 24,
                      	units: "metric",
                      		module:'MMM-PrayerTime',
                      		position: 'top_right',
                      			apiVersion: "1.0",
                      			lat: 55.841727,
                      			lon: 13.303381,
                      			timezone: 'Europe/Berlin',
                      			timeFormat: 24,
                      			method: 3,
                      			language: "en",
                      			alertTimer: 15000
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_right"
                      			header: "Ferien Deutschland",
                      						symbol: "calendar-check-o ",
                      			module: "compliments",
                      			position: "bottom_bar"
                      			module: "currentweather",
                      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                      			module: "weatherforecast",
                      			header: "Weather Forecast",
                      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      						title: "New York Times",
                      				showSourceTitle: true,
                      				showPublishDate: true
                      • G
                        govabm
                        sorry have a foult this is the file:
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "de",
                        	timeFormat: 24,
                        	units: "metric",
                        			apiVersion: "1.0",
                        			lat: 55.841727,
                        			lon: 13.303381,
                        			timeFormat: 24,
                        			method: 3,
                        			language: "en",
                        			alertTimer: 15000
                        			module: "alert",
                        			position: "top_bar"
                        			module: "clock",
                        			module: "newsfeed",
                        				feeds: [
                        the mirror works but i dont see the Modul
                        • G
                          govabm
                          it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
                          Barakallhufeek
                          • T
                            Tito
                            is it possible to add iqama times?
                              berlink36
                              Selamun Aleykum,
                              i want to set my own calculation method, how can i do this for Berlin
                              the calculation is very close to the method:
                              13=Diyanet İşleri Başkanlığı, Turkey
                              need some help,
                              module: “MMM-PrayerTime”,
                              position: “middle_center”, // This can be any of the regions. Best result is in the top_left/top_right.
                                                          apiVersion: "1.0", // please, leave unchanged. reserved for future use.
                                                          lat: "52.5069312", // latitude of your position (city)
                                                          lon: "13.1445453", // longitude of your position (city)
                                                          timezone: "Europe/Berlin", // please refer to http://php.net/manual/en/timezones.php
                                                          timeFormat: "24",
                                                          method: "13",
                                                          playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
                                                          notDisplayed: ["midnight", "sunset"],
                                                          useUpdateInterval: "true",
                                                          updateInterval: "86400 * 1000", // How often do you want to fetch new praying time? (milliseconds)
                                                          animationSpeed: "2.5 * 1000", // Speed of the update animation. (milliseconds)
                                                          language: "en",
                                                          showAdzanAlert: "true",
                                                          showTomorrow: "true",
                                                          alertTimer: "15000",
                                jawediqbal @slametps
                                @slametps
                                really a very helpful module.
                                Dawateislami provides the prayer time of thousands of locations around the globe.
                                https://prayertimes.dawateislami.net
                                  me.osama
                                  Hi Slamet PS and everyone,
                                  I am new to this stuff. started playing with raspberry pi during these lockdown days. I recently used MMM-PrayerTime module for my mirror.
                                  Currently i am showing prayer time and sunrise on my screen. i found 2 following issues.
                                  • adhan plays on time but stops at the very end of adhan. i mean it doesn’t play full adhan and misses about last approx 10 seconds of wma file. I googled and found out that the OXM player had that issue which should be solved after update. I tried to update and upgrade my PI but no luck.
                                  • Secondly it starts playing adhan at sunrie time. Whereas it shouldnt play adhan but may be some beeps sound or something for sunrise.
                                  Any help would be highly appreciated.
                                  JazakAllah
                                  • H
                                    heuss60100
                                    Salam ,
                                    The module work very well but when the adhan play i have a black screen and the mirror dont come again.
                                    What do you think about that?
                                    • slametpsS
                                      slametps @heuss60100
                                      @heuss60100 : So far, I didn’t face that problem. What MM version You use and you should check pm2 error log also.
                                      regards,
                                      Slamet PS
                                      • slametpsS
                                        slametps @me.osama
                                        @me-osama :
                                        sorry, I’m quite long time not monitoring this project. Is your problem solved?
                                        Please make sure this config option:
                                        regards,
                                        Slamet PS
                                        • 3 / 3
