    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 50.6k Views 14 Watching
    • G Offline
      govabm
      Salam Aleykum,
      i need help for the config.
      thats my File:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      		module:'MMM-PrayerTime',
      		position: 'top_right',
      			apiVersion: "1.0",
      			lat: 55.841727,
      			lon: 13.303381,
      			timezone: 'Europe/Berlin',
      			timeFormat: 24,
      			method: 3,
      			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
      			notDisplayed: ['midnight', 'sunset'],
      			useUpdateInterval: true,
      			updateInterval: 86400 * 1000,
      			animationSpeed: 2.5 * 1000,
      			language: "en",
      			showAdzanAlert: true,
      			alertTimer: 15000
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      			header: "Ferien Deutschland",
      						symbol: "calendar-check-o ",
      			module: "compliments",
      			position: "bottom_bar"
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      • G Offline
        govabm
        sorry have a foult this is the file:
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "de",
        	timeFormat: 24,
        	units: "metric",
        			apiVersion: "1.0",
        			lat: 55.841727,
        			lon: 13.303381,
        			timeFormat: 24,
        			method: 3,
        			language: "en",
        			alertTimer: 15000
        			module: "alert",
        			position: "top_bar"
        			module: "clock",
        			module: "newsfeed",
        				feeds: [
        the mirror works but i dont see the Modul
        • G Offline
          govabm
          it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
          Barakallhufeek
          • T Offline
            Tito
            is it possible to add iqama times?
              berlink36
              Selamun Aleykum,
              i want to set my own calculation method, how can i do this for Berlin
              the calculation is very close to the method:
              13=Diyanet İşleri Başkanlığı, Turkey
              need some help,
              module: “MMM-PrayerTime”,
              position: “middle_center”, // This can be any of the regions. Best result is in the top_left/top_right.
                                          apiVersion: "1.0", // please, leave unchanged. reserved for future use.
                                          lat: "52.5069312", // latitude of your position (city)
                                          lon: "13.1445453", // longitude of your position (city)
                                          timezone: "Europe/Berlin", // please refer to http://php.net/manual/en/timezones.php
                                          timeFormat: "24",
                                          method: "13",
                                          playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
                                          notDisplayed: ["midnight", "sunset"],
                                          useUpdateInterval: "true",
                                          updateInterval: "86400 * 1000", // How often do you want to fetch new praying time? (milliseconds)
                                          animationSpeed: "2.5 * 1000", // Speed of the update animation. (milliseconds)
                                          language: "en",
                                          showAdzanAlert: "true",
                                          showTomorrow: "true",
                                          alertTimer: "15000",
                jawediqbal @slametps
                @slametps
                really a very helpful module.
                Dawateislami provides the prayer time of thousands of locations around the globe.
                https://prayertimes.dawateislami.net
                  me.osama
                  Hi Slamet PS and everyone,
                  I am new to this stuff. started playing with raspberry pi during these lockdown days. I recently used MMM-PrayerTime module for my mirror.
                  Currently i am showing prayer time and sunrise on my screen. i found 2 following issues.
                  • adhan plays on time but stops at the very end of adhan. i mean it doesn’t play full adhan and misses about last approx 10 seconds of wma file. I googled and found out that the OXM player had that issue which should be solved after update. I tried to update and upgrade my PI but no luck.
                  • Secondly it starts playing adhan at sunrie time. Whereas it shouldnt play adhan but may be some beeps sound or something for sunrise.
                  Any help would be highly appreciated.
                  JazakAllah
                  slametpsS 1 Reply Last reply Reply Quote 0
                  • H Offline
                    heuss60100
                    Salam ,
                    The module work very well but when the adhan play i have a black screen and the mirror dont come again.
                    What do you think about that?
                    • slametpsS Offline
                      slametps @heuss60100
                      @heuss60100 : So far, I didn’t face that problem. What MM version You use and you should check pm2 error log also.
                      regards,
                      Slamet PS
                      • slametpsS Offline
                        slametps @me.osama
                        @me-osama :
                        sorry, I’m quite long time not monitoring this project. Is your problem solved?
                        Please make sure this config option:
                        regards,
                        Slamet PS
                        • 3 / 3
