    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 49.7k Views 14 Watching
    • slametpsS Offline
      slametps
      Description:
      A MM-module to display moslem praying time from https://aladhan.com.
      Download:
      [card:slametps/MMM-PrayerTime]
      Screenshot
      Initial Version
      regards,
      Slamet PS
      A Z 2 Replies Last reply Reply Quote 1
        AAPS @slametps
        @slametps While looking at this on GitHub, it seems like it plays Adhan as well. Is this correct? If so, could I make it not play Adhan, or does it come standard with the module?
        I’ve been looking for a module like this since I started. Thank you. :grinning:
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @AAPS
          @AAPS you can set config playAdzan as following to tell module NOT to play adzan:
          playAdzan: [],
          regards,
          Slamet PS
            AAPS @slametps
            @slametps Thanks! This’ll work much better than the calendar method.
            • Z Offline
              zzaidi148 @slametps
              @slametps Thank you for making this module. I just wanted to ask you why my config wouldn’t validate. I am in central north america. This is my config:
              			module: 'MMM-PrayerTime',
              			position: 'bottom_right',
              			apiVersion: '1.0'
              			lat: 38.033184,
              			lon: -86.625225,
              			timezone: true,
              			method: 5,
              			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
              			notDisplayed: ['midnight', 'sunset'],
              			useUpdateInterval: true,
              			updateInterval: 86400 * 1000,
              			animationSpeed: 2.5 * 1000,
              			language: config.language,
              			showAdzanAlert: true,
              			alertTimer: 15000
              • yawnsY Offline
                yawns Moderator @zzaidi148
                @zzaidi148
                There is a comma missing after apiVersion: '1.0'
                Z 1 Reply Last reply Reply Quote 0
                • Z Offline
                  zzaidi148 @yawns
                  @yawns tried that but didn’t work. I think it has to be something with the timezone.
                  • slametpsS Offline
                    slametps @zzaidi148
                    @zzaidi148 said in MMM-PrayerTime:
                    There is a missing comma after apiVersion: '1.0'. What does not work? What you get on your mirror? Or in pm/mm log?
                    regards,
                    Slamet PS
                    • N Offline
                      noorm91
                      I am having trouble with my module…
                                                      apiVersion: '1.0',
                                                      lat: 55.841727,
                                                      lon: 13.303381,
                                                      timezone: Europe/Stockholm,
                                                      method: 3,
                                                      alertTimer: 15000
                      can you see anything wrong?
                      • slametpsS Offline
                        slametps @noorm91
                        @noorm91 said in MMM-PrayerTime:
                                                       apiVersion: '1.0',
                                                       lat: 55.841727,
                                                       lon: 13.303381,
                                                       method: 3,
                                                       alertTimer: 15000
                        It should be timezone: 'Europe/Stockholm'.
                        regards,
                        Slamet PS
                        • Z Offline
                          zzaidi148 @slametps
                          @slametps The mirror cannot validate the config.
                          • Z Offline
                            zzaidi148 @zzaidi148
                            @slametps It cannot read propert ‘language’
                            • N Offline
                              noorm91
                                                  position: 'top_right',
                                                          apiVersion: '1.0',
                                                          lat: 55.841727,
                                                          lon: 13.303381,
                                                          timezone: 'Europe/Stockholm',
                                                          method: 3,
                                                          alertTimer: 15000
                              Salam, changed it but still not working :( lon/lat: is ok? how about language: ?
                              Actually this is my first module I’m trying to get working, pretty new to MM2 so maybe I need to change somewhere else too.
                              The module is under here;
                              pi@raspberrypi:~/MagicMirror/modules $ ls
                              default MMM-PrayerTime node_modules README.md
                              pi@raspberrypi:~/MagicMirror/modules/MMM-PrayerTime $ ls
                              LICENSE MMM-PrayerTime.css MMM-PrayerTime.js node_helper.js README.md res screenshot2.jpg screenshot-alert.png screenshot.png translations
                              • slametpsS Offline
                                slametps @noorm91
                                                            apiVersion: '1.0',
                                                            lat: 55.841727,
                                                            lon: 13.303381,
                                                            method: 3,
                                                            alertTimer: 15000
                                You may simply remove language: config.language line, and see if this work. It tells MMM-PrayerTime module to use MM global language config. If not work, please use 'en' for language entry.
                                regards,
                                Slamet PS
                                • N Offline
                                  noorm91
                                  Alhamdulillah almost there, the module shows up in top_right with this conf, but it just says " Loading … " any known reason?
                                                              apiVersion: '1.0',
                                                              lat: 55.841727,
                                                              lon: 13.303381,
                                                              timezone: "Europe/Stockholm",
                                                              method: 3,
                                                              language: 'en',
                                                              alertTimer: 15000
                                  • slametpsS Offline
                                    slametps @noorm91
                                    @noorm91 can you post the pm2/mm log?
                                    regards,
                                    Slamet PS
                                    • Z Offline
                                      zzaidi148 @slametps
                                      @slametps Alhamdulillah I got it work by taking out the language line. It works well now. I was wondering if there was any way I could take out the Imsak times from the module and to have the times be in a 12 hour format. Also, how do I make sure that it plays the athan? Thanks for all the help!
                                      • slametpsS Offline
                                        slametps @zzaidi148
                                        You can remove Imsak from the schedule by adding config notDisplayed: ['midnight', 'sunset', 'imsak']. Currently, support 24-hour format only.
                                        Your MM has speaker? If yes, you can check type following command in console:
                                        /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3
                                        It will play adzan.mp3.
                                        regards,
                                        Slamet PS
                                        • N Offline
                                          noorm91
                                          I will try get the log when I’m home, just a simple question, does this work with Midori browser, because that is the one I’m using on Rpi 1 model b…I entered my Rpi IP address in chrome from my computer and then I saw the module perfectly.
                                          slametpsS A 2 Replies Last reply Reply Quote 0
                                          • slametpsS Offline
                                            slametps @noorm91
                                            Sorry, I haven’t test it on midori browser.
                                            regards,
                                            Slamet PS
