    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 54.9k Views 14 Watching
    • slametpsS Offline
      slametps @slametps
      Adzan is played at server side (rpi) by omxplayer. You have to install omxplayer.
      regards,
      Slamet PS
        aishaamila @slametps
        @slametps I try to play the adzan using /usr/bin/omxplayer -o hdmi modules/MMM-PrayerTime/res/adzan.mp3 and it played… Do i still need to install the omxplayer?
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @aishaamila
          @aishaamila can you post your config?
          regards,
          Slamet PS
          A 2 Replies Last reply Reply Quote 0
            @aishaamila But i need to change hdmi to local, i wil send it when i get home… Thank you so much
              @slametps do i need to change something?
              		module: "MMM-PrayerTime",
              			apiVersion: "1.0",
              			lat: 2.1484105,
              			lon: 102.7285677,
              			timezone: "Asia/Kuala Lumpur",
              			timeFormat: 24,
              			method: 4,
              			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
              			notDisplayed: ['midnight', 'sunset'],
              			useUpdateInterval: true,
              			updateInterval: 86400 * 1000,
              			animationSpeed: 2.5 * 1000,
              			showAdzanAlert: true,
              			alertTimer: 15000
              • slametpsS Offline
                @aishaamila
                timezone: "Asia/Kuala_Lumpur",
                regards,
                Slamet PS
                • slametpsS Offline
                  @aishaamila said in MMM-PrayerTime:
                  What do you mean by “need to change hdmi to local”? Audio output using “-o hdmi” option by omxplayer is output to monitor/TV via HDMI line.
                  regards,
                  Slamet PS
                  • slametpsS Offline
                    slametps @slametps
                    @slametps said in MMM-PrayerTime:
                    @aishaamila
                    As described in http://php.net/manual/en/timezones.asia.php.
                    regards,
                    Slamet PS
                      @slametps /usr/bin/omxplayer -o local modules/MMM-PrayerTime/res/adzan.mp3
                      I use this command to play the adzan and it worked, but during the time it didnt played. That’s why I am confused.
                        @slametps okay I will try this first thankyou so much
                          @slametps it still not working?is there any problem with time interval?
                          • G Offline
                            govabm
                            Salam Aleykum,
                            i need help for the config.
                            thats my File:
                            /* Magic Mirror Config Sample
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "de",
                            	timeFormat: 24,
                            	units: "metric",
                            		module:'MMM-PrayerTime',
                            		position: 'top_right',
                            			apiVersion: "1.0",
                            			lat: 55.841727,
                            			lon: 13.303381,
                            			timezone: 'Europe/Berlin',
                            			timeFormat: 24,
                            			method: 3,
                            			language: "en",
                            			alertTimer: 15000
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_right"
                            			header: "Ferien Deutschland",
                            						symbol: "calendar-check-o ",
                            			module: "compliments",
                            			position: "bottom_bar"
                            			module: "currentweather",
                            				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                            			module: "weatherforecast",
                            			header: "Weather Forecast",
                            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title: "New York Times",
                            				showSourceTitle: true,
                            				showPublishDate: true
                            • G Offline
                              govabm
                              sorry have a foult this is the file:
                               * MIT Licensed.
                              var config = {
                              	port: 8080,
                              	language: "de",
                              	timeFormat: 24,
                              	units: "metric",
                              			apiVersion: "1.0",
                              			lat: 55.841727,
                              			lon: 13.303381,
                              			timeFormat: 24,
                              			method: 3,
                              			language: "en",
                              			alertTimer: 15000
                              			module: "alert",
                              			position: "top_bar"
                              			module: "clock",
                              			module: "newsfeed",
                              				feeds: [
                              the mirror works but i dont see the Modul
                              • G Offline
                                govabm
                                it works ! i think i have a Problem with the mm.sh data i have install complet new smart mirror to an SD now it Works
                                Barakallhufeek
                                • T Offline
                                  Tito
                                  is it possible to add iqama times?
                                    berlink36
                                    Selamun Aleykum,
                                    i want to set my own calculation method, how can i do this for Berlin
                                    the calculation is very close to the method:
                                    13=Diyanet İşleri Başkanlığı, Turkey
                                    need some help,
                                    module: “MMM-PrayerTime”,
                                    position: “middle_center”, // This can be any of the regions. Best result is in the top_left/top_right.
        apiVersion: "1.0", // please, leave unchanged. reserved for future use.
        lat: "52.5069312", // latitude of your position (city)
        lon: "13.1445453", // longitude of your position (city)
        timezone: "Europe/Berlin", // please refer to http://php.net/manual/en/timezones.php
        timeFormat: "24",
        method: "13",
        playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
        notDisplayed: ["midnight", "sunset"],
        useUpdateInterval: "true",
        updateInterval: "86400 * 1000", // How often do you want to fetch new praying time? (milliseconds)
        animationSpeed: "2.5 * 1000", // Speed of the update animation. (milliseconds)
        language: "en",
        showAdzanAlert: "true",
        showTomorrow: "true",
        alertTimer: "15000",
                                      jawediqbal @slametps
                                      @slametps
                                      really a very helpful module.
                                      Dawateislami provides the prayer time of thousands of locations around the globe.
                                      https://prayertimes.dawateislami.net
                                        me.osama
                                        Hi Slamet PS and everyone,
                                        I am new to this stuff. started playing with raspberry pi during these lockdown days. I recently used MMM-PrayerTime module for my mirror.
                                        Currently i am showing prayer time and sunrise on my screen. i found 2 following issues.
                                        • adhan plays on time but stops at the very end of adhan. i mean it doesn’t play full adhan and misses about last approx 10 seconds of wma file. I googled and found out that the OXM player had that issue which should be solved after update. I tried to update and upgrade my PI but no luck.
                                        • Secondly it starts playing adhan at sunrie time. Whereas it shouldnt play adhan but may be some beeps sound or something for sunrise.
                                        Any help would be highly appreciated.
                                        JazakAllah
                                        • H Offline
                                          heuss60100
                                          Salam ,
                                          The module work very well but when the adhan play i have a black screen and the mirror dont come again.
                                          What do you think about that?
                                          • slametpsS Offline
                                            slametps @heuss60100
                                            @heuss60100 : So far, I didn’t face that problem. What MM version You use and you should check pm2 error log also.
                                            regards,
                                            Slamet PS
                                            • 3 / 3
