    [SOLVED] Anyone tried MMM-mqtt?
    19 Posts 5 Posters 16.2k Views 7 Watching
      dantodd @xbmcnut
      @xbmcnut said in Anyone tried MMM-mqtt?:
      I have MQTT working now and pulling in data (Temperature) from a remote MQTT broker. Don’t think MMM-mqtt is going to handle your alert natively. You’d need something like Home Assistant to manage the automation?
      I have mosquito running I just want to send an alert to the alert module when I receive a notification that the mail was delivered on the topic: /sensors/mailbox
      • cowboysdudeC Offline
        cowboysdude Module Developer @xbmcnut
        @dantodd said in Anyone tried MMM-mqtt?:
        I know this is an old topic but hopefully someone has started using this module and can help out. I am looking for a way to have mqtt fire off an alert box when it receives a specific message on a particular topic. I haven’t really worked with alerts either.
        I am hoping I can do the same as you but using openHab…
          Would you care to share how you did it? Thanks!
          X 1 Reply Last reply Reply Quote 0
            MrEdOne
            Hello. @xbmcnut i tried to use this module to connect to my home assistant broker with login and password but no success.
            How can i show a state of my sensors from Esp8266 connected to home assistant via mqtt on my mirror?
            X 1 Reply Last reply Reply Quote 1
            • X Offline
              xbmcnut @MrEdOne
              @MrEdOne said in Anyone tried MMM-mqtt?:
              As per the instructions here https://github.com/javiergayala/MMM-mqtt, sadly MMM-mqtt “Currently only supports unencrypted/unauthenticated MQTT connections” so it won’t work on a broker that has a username and password set up.
                @xbmcnut No sure it’ll work for me… haven’t looked into but we’ll see. I need it to make a connection with OpenHab.
                • X Offline
                  xbmcnut @cowboysdude
                  @cowboysdude said in Anyone tried MMM-mqtt?:
                  Here is my config:
                  			module: 'MMM-mqtt',
                  			position: 'bottom_left',
                  			header: 'Office Temperature', // This is optional
                  				mqttServer: 'mqtt://10.0.2.8', //Connection string for the server to connect to (mqtt://localhost)
                  				topic: '/garage/dallas/temperature',
                  				postText: ' °C'
                  • X Offline
                    If you are using a MQTT broker, MMM-mqtt will work with any HA system as it’s only subscribing to a MQTT topic.
                    cowboysdudeC 1 Reply Last reply Reply Quote 1
                      @xbmcnut Great to know!! Thank you!
                      Going to build a module to show the temp from this on the mirror:
                      https://hestiapi.com/
                      At some point would like to be able to change the temp as well but just getting it to show the temp right now would be awesome :)
                      • X Offline
                        Should be pretty easy if that device can publish the temperature to a broker.
