    [SOLVED] Anyone tried MMM-mqtt?
    19 Posts 5 Posters 17.7k Views 7 Watching
    • cowboysdudeC
      Not as of yet but a project I"m interested in will require it so I’m curious as to how this works out…
        dantodd
        I know this is an old topic but hopefully someone has started using this module and can help out. I am looking for a way to have mqtt fire off an alert box when it receives a specific message on a particular topic. I haven’t really worked with alerts either.
        X 1 Reply Last reply Reply Quote 0
        • X
          xbmcnut @dantodd
          @dantodd said in Anyone tried MMM-mqtt?:
          I have MQTT working now and pulling in data (Temperature) from a remote MQTT broker. Don’t think MMM-mqtt is going to handle your alert natively. You’d need something like Home Assistant to manage the automation?
          D cowboysdudeC 3 Replies Last reply Reply Quote 0
            dantodd @xbmcnut
            @xbmcnut said in Anyone tried MMM-mqtt?:
            I have mosquito running I just want to send an alert to the alert module when I receive a notification that the mail was delivered on the topic: /sensors/mailbox
            • cowboysdudeC
              cowboysdude Module Developer @xbmcnut
              I am hoping I can do the same as you but using openHab…
              • cowboysdudeC
                Would you care to share how you did it? Thanks!
                  MrEdOne
                  Hello. @xbmcnut i tried to use this module to connect to my home assistant broker with login and password but no success.
                  How can i show a state of my sensors from Esp8266 connected to home assistant via mqtt on my mirror?
                  X 1 Reply Last reply Reply Quote 1
                  • X
                    xbmcnut @MrEdOne
                    @MrEdOne said in Anyone tried MMM-mqtt?:
                    As per the instructions here https://github.com/javiergayala/MMM-mqtt, sadly MMM-mqtt “Currently only supports unencrypted/unauthenticated MQTT connections” so it won’t work on a broker that has a username and password set up.
                    • cowboysdudeC
                      @xbmcnut No sure it’ll work for me… haven’t looked into but we’ll see. I need it to make a connection with OpenHab.
                      • X
                        xbmcnut @cowboysdude
                        @cowboysdude said in Anyone tried MMM-mqtt?:
                        Here is my config:
                        			module: 'MMM-mqtt',
                        			position: 'bottom_left',
                        			header: 'Office Temperature', // This is optional
                        				mqttServer: 'mqtt://10.0.2.8', //Connection string for the server to connect to (mqtt://localhost)
                        				topic: '/garage/dallas/temperature',
                        				postText: ' °C'
                        • X
                          If you are using a MQTT broker, MMM-mqtt will work with any HA system as it’s only subscribing to a MQTT topic.
                          • cowboysdudeC
                            @xbmcnut Great to know!! Thank you!
                            Going to build a module to show the temp from this on the mirror:
                            https://hestiapi.com/
                            At some point would like to be able to change the temp as well but just getting it to show the temp right now would be awesome :)
                            • X
                              Should be pretty easy if that device can publish the temperature to a broker.
                              • cowboysdudeC
                                @xbmcnut It can. I have ‘the guide’ another user put together for the thermostat and now this module! :) Shouldn’t be too bad. Just have to find time to really focus on it… perhaps this weekend. I’m just so busy.
                                • cowboysdudeC
                                  Is there a way to seek multiple topics without having to run the module several times? Like using an array …
                                  • X
                                    @cowboysdude said in [SOLVED] Anyone tried MMM-mqtt?:
                                    Yes, you can add another entity in the same position and it will add it below the older one (including the title)
                                    • cowboysdudeC
                                      Are you referring to running the module more than once in the config.js and in the same position?
                                      That is what I’m doing but adding the entry 7 times to my config would be a bit tedious :)
                                      • axellejamousA
                                        axellejamous
                                        I was wondering if any of you know how to actually subscribe and publish to a topic using this module? I currently tried adding two different modules to the config file and have one set as sending and one as receiving but that just causes the module to crash. Has anyone figured out how to do both of these at the same time?
