    Get URL from Newsfeed (full article)
    4 Posts 2 Posters 2.3k Views 2 Watching
      Sennahoj82
      How do I get the url of the full article of the shown newsfeed?
      With
      var title = this.newsItems[this.activeItem].title;
      I get the headline of the newsfeed.
      With
      var description = this.newsItems[this.activeItem].description;
      I get the description of the newsfeed.
      But
      var url = this.newsItems[this.activeItem].url;
      does not show anything.
      With this URL I want to open the full article of the newsfeed. What do I wrong?
      Greetings from Thuringia/Germany
      • yawnsY Offline
        yawns Moderator
        Which newsfeed are you using? Did you open your newsfeed in a browser to see if there is an entry with url or link?
        fetcher.js does this:
        var url = item.url || item.link || "";
        So if you use the default news feed http://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml you see there is an entry link as a child node of item. Maybe your newsfeed uses something other than url or link?
          Sennahoj82
          Hi yawns.
          I am using these newsfeeds http://www.tagesschau.de/xml/rss2 and https://thib24.de/feed.
          I see no difference between the default newsfeed and my.
          So I myself have tried the default newsfeed and it also won’t work.
          If I put out the url to log information
          var url = this.newsitems[this.activeItem].url;
          Log.info("Article_URL " + url);
          the browser provide this information: Article_URL undefined.
            Sennahoj82
            Ok.
            I’ve solved the problem. There wasn’t a url decleration in my fetcher.js.
            I put it in to the fetcher.js an it works very well now.
            Thanks for your help.
            Great forum.
