    npm start dev doesn't work
    3 Posts 2 Posters 5.3k Views 2 Watching
    • romainR Offline
      romain
      When I try to run “npm start dev” or “DISPLAY=:0 npm start dev” I got an error tellming me that “start” doesn’t exist
      pi@raspberrypi:~ $ npm start dev
      pm ERR! missing script: start
      npm ERR!     /home/pi/.npm/_logs/2017-03-30T15_11_52_091Z-debug.log
      The log file mentioned in that message contain:
      pi@raspberrypi:~ $ cat /home/pi/.npm/_logs/2017-03-30T15_11_52_091Z-debug.log
      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start', 'dev' ]
      2 info using npm@4.4.4
      3 info using node@v6.9.4
      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
      5 verbose stack Error: missing script: start
      5 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)
      5 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:61:5
      5 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:356:5
      5 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:320:45)
      5 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:354:3)
      5 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:124:5)
      5 verbose stack     at ReadFileContext. (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:295:20)
      5 verbose stack     at ReadFileContext.callback (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16)
      5 verbose stack     at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:365:13)
      6 verbose cwd /home/pi
      7 verbose Linux 4.4.21-v7+
      8 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
      9 verbose node v6.9.4
      10 verbose npm  v4.4.4
      11 error missing script: start
      12 verbose exit [ 1, true ]
      How can I fix that issue ?
        broberg Project Sponsor @romain
        @romain you have to get in to the magic mirror folder first before you can run npm start
        Ie type
        cd MagicMirror
        And then
        npm start
        Or
        display=:0 npm start
        If you are running it via ssh
        • romainR Offline
          romain
          Oh ! Thanks !! It work
