    Update V2.1.1 error
    6 Posts 2 Posters 3.0k Views 2 Watching
    • N Offline
      Nonamexp
      Hello,
      I make the update and have this error:
      root@raspberrypi:/home/pi/MagicMirror# npm install
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: graceful-fs v3.0.0 and before will fail on node releases >= v7.0. Please update to graceful-fs@^4.0.0 as soon as possible. Use 'npm ls graceful-fs' to find it in the tree.
      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
      npm WARN prefer global colorguard@1.2.0 should be installed with -g
      > electron-prebuilt@1.4.13 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
      > node install.js
      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
      npm WARN prefer global pm2@2.0.18 should be installed with -g
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
      npm ERR! node v4.7.3
      npm ERR! npm  v2.15.11
      npm ERR! code EPEERINVALID
      npm ERR! peerinvalid The package stylelint@7.4.2 does not satisfy its siblings' peerDependencies requirements!
      npm ERR! peerinvalid Peer stylelint-config-standard@16.0.0 wants stylelint@^7.8.0
      help me pls :O
      daenickD 1 Reply Last reply Reply Quote 0
      • daenickD Offline
        daenick @Nonamexp
        @Nonamexp Hello, some time ago, I get a similar error but no here, was while I want to install node.
        My solution was install those packages:
        Minimatch anda Graceful manually.
        By the way, do yo follow te exact instructions forma the upgrade?
        2.1.1] - 2017-04-01
        Note: This update uses new dependencies. Please update using the following command: git pull && npm install
        • N Offline
          Nonamexp @daenick
          @daenick I have first ‘git pull’ and after ‘npm install’
          • daenickD Offline
            daenick
            Weird, I have no problem with the update. Try to install each packages manually:
            minimatch and graceful
            • N Offline
              Nonamexp @daenick
              @daenick Have your advice followed and the problem persists. At the first magic mirror it went through without problems but the second I have the error
              • daenickD Offline
                daenick @Nonamexp
                @Nonamexp In this case I think you need to do a clean install…
