    PIR sensor not working after installation
    6 Posts 3 Posters 3.1k Views 4 Watching
    • V Offline
      vicdilou
      Hi everyone !
      I followed the steps of the readme, but after rebooting the screen never turns off.
      I don’t know where I am wrong but it doesn’t work ^^
      Thank you.
      https://github.com/paviro/MMM-PIR-Sensor
      • hartattackH Offline
        hartattack
        Is the sensor pin configured properly? Meaning in the config file for the module, the sensor pin defaults to 22. Is that the same one your sensor is connected to?
        V 2 Replies Last reply Reply Quote 0
        • V Offline
          vicdilou @hartattack
          @hartattack I connected the sensor to the pin 22. I didn’t change anything else.
          • V Offline
            vicdilou
            UP ! :)
            I need help please ^^
            • V Offline
              I test the sensor with this, but it marks indefinitely “motion detected”.
              from gpiozero import MotionSensor
              pir = MotionSensor(4)
              while True:
                  if pir.motion_detected:
                      print("Motion detected!")
              Edit : I connected it to the GPIO 4
                spacejam
                I’m having the same issue. Should the screensaver be off? I did the original config;
                sudo nano /etc/xdg/lxsession/LXDE/autostart
                add the following lines:
                @xset s noblank
                @xset s off
                @xset -dpms
                sudo nano /etc/lightdm/lightdm.conf
                xserver-command=X -s 0 -dpms
                but the screen was still blanking after 10-15 minutes so I installed xscreensaver to get around this. I’ve now taken xscreensaver off, so the screen is blanking after inactivity again, but MM doesn’t seem to recognize the PIR. I get the same results of ‘Motion Detected’ when running a .py test from the OS.
