    Screen Font is too big
    17 Posts 4 Posters 15.5k Views 6 Watching
      Menn80 @yo-less
      @yo-less
      Alright, so if the default says 70% and I have told it to go to 100% in the body of the custom.css file I did exactly what I did not want, I went bigger. That I can understand. Should I change the custom.css file from saying
      body {
      .small {
      font-size: 10px;
      to
      .small {
      font-size: 10px;
      also if my modules are using % should I use % instead of px or any other of the .css variants? My thought on the theory is it shouldn’t matter but sometimes my theory is so very wrong.
      Thank you for explaining things to me, I am very new to this coding concept. I should have paid more attention to how this all works when I was younger!
      Andy
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Menn80
        @Menn80 thats wrong Syntax in Plain CSS You can’t Nest like this. You have to do: .modulename .small { font-size: 10px; } and don’t put it between the Curly braces of body, that is just an example and Not necessary
          Menn80 @strawberry 3.141
          @strawberry-3.141
          So I can pretty much remove the body writing that is in the .css file from the start?
          Andy
            @Menn80 exactly
              @strawberry-3.141
              Cool, I tried that only with
              body .small {font-size: 10px;}
              and that worked. Is this just a lazy solution? It seems like the only think that might pop up is if I do like the size of one module but I do of another. Can I than include line spacing in on that too? if so would I just add it like so?
              body .small {font-size: 10px; line-height 15px;}
              Andy
              yo-lessY 1 Reply Last reply Reply Quote 0
                you can put as much css rules into the curly braces as you want
                you changed the small class for everything in the body tag and everything displayed on the mirror is in the body tag, so it’s affected for all elements using the small class, the other rule affected only the small class using elements in the specific module
                • yo-lessY Offline
                  yo-less Module Developer @Menn80
                  @Menn80 You can go as far as only writing
                  .small {
                      font-size: 10 px;
                  No need for the ‘body’ tag.
