    Updated MMM and MMM-PIR, Monitor turns on and stays black
    mmm-pir
    3 Posts 3 Posters 2.2k Views 2 Watching
    • H Offline
      H1ghtower
      Hi there,
      I really like this Project, and after having it on my Desk for a while reminding me to do some Updates (Magic Mirror itself and the PIR-Module), unfortunately switching to PM2 for autostart in the same Process, I’m Stuck on the problem, that the Monitor starts getting a Signal, once the motion is detected, but the only thing I’m able to see is de working Backlight.
      If i do a reboot, evrything is working, as long as the Monitor stays on. After being switched off an on by the PIR-Module, it stays black except the Backlight comming up.
      Any Hints welcome !
      Hightower
        broberg Project Sponsor @H1ghtower
        @H1ghtower sounds like a screensaver issue since the monitor actually turns on
        • P Offline
          Projekt95
          Hey!
          Deactivate screensaver if not done yet.
          That may be a cause.
          How do you controll the display? Are you using a command like /opt/vc/nin/tvservice -o and /opt/vc/nin/tvservice -p or just tvservice -o?
          And is the display connected via hdmi?
          If that’s the case you could try the following:
          In /boot/config.txt add hdmi_blanking=1 and reboot. Now try HDMI Output OFF with vcgencmd display_power 0 and HDMI Output ON with vcgencmd display_power 1 instead of the command above.
          Descript here. :)
