    AlexaPi
    28 Posts 4 Posters 14.9k Views 4 Watching
    • johnnyboyJ Offline
      johnnyboy @davidrq7
      This post is deleted!
      johnnyboyJ 1 Reply Last reply Reply Quote 0
        johnnyboy @johnnyboy
        • romainR Offline
          romain
          Not completly sure about this but the http server : 5055 might just be the port AlexaPi using to comunicate with the MagicMirror module MMM-AlexaPi . I do have the same message and it doesn’t prevent AlexaPi to work
            davidrq7
            Guys i get a little succes.
            I got the token from amazon, i set the sound and when i start alexa service she is active but i got rly nasty problem with this port 5055. I have no idea what to do next0_1492711999352_18034766_1562333477133204_1450890660_n.jpg
            romainR 1 Reply Last reply Reply Quote 0
            • romainR Offline
              romain @davidrq7
              @davidrq7 This mean you have already an instance of alexaPi running. reboot or kill the already running alexapi
                davidrq7
                Y, but even when i stop alexa service and start it again it looks all the same. Any sugestions? :) im getting closer to the end ^^
                  johnnyboy @davidrq7
                    davidrq7 @johnnyboy
                    @johnnyboy i’ll check this tomorrow by using sudo netstat -lnptu to check which application is blocking 5055 or 5050 port
                      johnnyboy @davidrq7
                      • lucallmonL Offline
                        lucallmon
                        i had errors installing the current version 1.5, so I reverted back to v1.4 which is much more stable. this is the version that I am currently running flawlessly.
                        cd /opt/AlexaPi
                        sudo git checkout v1.4
                        I hope this helps
                        • 2 / 3
