Navigation
    • Search
    SOLVED Editing Default Settings
    Troubleshooting
    • LeashP15
      LeashP15 last edited by
      I was able to install the Magic Mirror and pull up the sample config file; however, it will not allow me to edit it. For example, I’d like to change the weather to be for my area instead of New York. How do I fix this?
      broberg 1 Reply Last reply Reply Quote 0
      • broberg
        broberg Project Sponsor @LeashP15 last edited by
        @LeashP15 did you copy the sample config file first? ( So you have config.js instead of config.js.sample)?
        Are you using the nano text editor to edit the file?
        Have you gotten your own api-key for the weather modules?
        • LeashP15
          @broberg what would the code line look like for that? I copied what it had in the MagPi pdf file. I did use the nano text editor, but it didn’t allow me to edit, and yes I have my own api-key for the weather modules.
          • broberg
            @LeashP15
            to copy and rename the config.js.sample file you write
            cp config/config.js.sample config/config.js
            to edit using nano with sudo
            sudo nano config/config.js
            based on that you are in the MagicMirror folder to start with.
            • LeashP15
              @broberg
              It created an empty config file. Should I just rewrite everything, but change the parts that I needed changed?
              • broberg
                @LeashP15 that’s odd, it shouldn’t be empty unless your sample file is empty.
                do this first
                rm config/config.js(It’s to remove the empty config.js file)
                and then do the copy again
                LeashP15 1 Reply Last reply Reply Quote 0
                • LeashP15
                  LeashP15 @broberg last edited by
                  @broberg It finally worked! Thanks for your help!
                  • broberg
                    broberg Project Sponsor @LeashP15 last edited by broberg
                    @LeashP15 you’re welcome! 🙂
