    MMM-Myvoiceradio with button
    1 Posts 1 Posters 984 Views 1 Watching
    • B
      Blackmirror
      Hello,
      I need help, I will use the MMM-Myvoiceradio module with buttons not this microphon.
      I have make buttone with MMM-Buttons for
      Sender+ to switch to the next sender and
      Sender- to switch to the previous sender
      VolumeUp to make a higher Volumen and
      VolumeDown to make a lower Volumen
      and radiostop for stop the radio.
      And have change the MMM-Myvoiceradio.js
      but nothing works.
      But I muss learn a lot of Javascript
      Module.register(“MMM-Myvoiceradio”,{
      // Default module config.
      // defaults: { text: “
      Sender1: BigFM
      Sender2: Einslive
      notificationReceived: function(notification, payload, sender) {
      var self = this;
      Sender = 0;
      If (notification === “Sender+”){
      Sender = Sender+1;
      If (Sender > 2){
      Sender = 1;
      If (notification === “Sender-”){
      Sender = Sender-1;
      If (Sender < 1){
      Sender = 2;
      if (Sender === 1){
      self.sendSocketNotification(‘einslive’, {});
      if (Sender === 2){
      self.sendSocketNotification(‘bigfm’, {});
      if (notification === “VolumeUp”){
      self.sendSocketNotification(‘VolumeUp’, {});
      if (notification === “VolumeDown”){
      self.sendSocketNotification(‘VolumeDown’, {});
      if (notification === “radiostop”){
      self.sendSocketNotification(‘radiostop’, {});
          // Override dom generator.
          getDom: function() {
                  wrapper.innerHTML = this.config.text;
                  return wrapper;
