    Not again PIR
    10 Posts 2 Posters 5.2k Views 2 Watching
    • X Offline
      xeroxu
      And again me ;). I can not see how my MagicMirror can work so far with my ignorance ok not really Ignorance but Noob, Noob, and for Luck I got Help from her e (THX Mykle1). But now I dont now what really happend, Ihave an PIR 501 and worked really fine with the Module MMM-PIR-Sensor. But now after I put all together in my Frame the Monitor goes off after 2 minuets but turns on b himself after ca. 30 seconds.That never happend befor I had it “free air”. Ok maybe its one or athe module wiche works not together. BTW. I am using a Raspbery PI 3. Edit the Monitor now doesnt turn off :(
        Damian @xeroxu
        @xeroxu
        https://forum.magicmirror.builders/topic/2266/problem-with-my-pir-sensor
        • X Offline
          xeroxu
          @Damian Thank you, now I got me a Ferrit Bead but it still dont not work. Maybe my coding or my cabling is wrong.
          		module: 'MMM-PIR-Sensor',
          	sensorPIN: 22,
                                          powerSaving: true
          • X Offline
            xeroxu
            Now that I deleted and reinstalled the module a new problem shows up . After I put the code In my config.js the Monitor stays black after the reboot. I testet the PIR its not broken.
            • X Offline
              xeroxu
              Problem solved :)
                Damian @xeroxu
                @xeroxu
                How did you manage the fix what was wrong? thank you
                • X Offline
                  xeroxu
                  @Damian I did after i checked the PIR a new npm install in the MM-PIR-Sensor Folder and changed the Sensor Pin to 25 (its the GPIO PIN) wrong thinking thats why I am a Noob ;)
                    Damian
                    @xeroxu said in Not again PIR:
                    Me too but i learn here by reading everything and try to understand better. thank you for reply it will help me too
                    X 1 Reply Last reply Reply Quote 0
                    • X Offline
                      xeroxu @Damian
                      @Damian no prob. im learning from reading and asking?
                      • X Offline
                        xeroxu
                        And again after two days the mirror did what he wants . I was nearly at that Point to throw all away and start fom beginning. Baut then i tried a thing , I disabled Bluetooth AND WLAN. And did it that way:
                        //sudo nano /etc/modprobe.d/raspi-blacklist.conf
                        blacklist brcmfmac
                        blacklist brcmutil
                        blacklist cfg80211
                        blacklist rfkill
                        blacklist btbcm
                        blacklist hci_uart
                        And after that a Reboot and
                        //sudo systemctl disable hciuart
                        and another reboot .
                        This works, I hope longer then 2 Days ;)
                        Now I have to work with the Ethernetport and gonna try it with an USB Wlan Dongle
