    Not again PIR
    10 Posts 2 Posters 4.8k Views 2 Watching
    • X Offline
      xeroxu
      Now that I deleted and reinstalled the module a new problem shows up . After I put the code In my config.js the Monitor stays black after the reboot. I testet the PIR its not broken.
      • X Offline
        xeroxu
        Problem solved :)
          Damian @xeroxu
          @xeroxu
          How did you manage the fix what was wrong? thank you
          • X Offline
            xeroxu
            @Damian I did after i checked the PIR a new npm install in the MM-PIR-Sensor Folder and changed the Sensor Pin to 25 (its the GPIO PIN) wrong thinking thats why I am a Noob ;)
              Damian
              @xeroxu said in Not again PIR:
              Me too but i learn here by reading everything and try to understand better. thank you for reply it will help me too
              X 1 Reply Last reply Reply Quote 0
              • X Offline
                xeroxu @Damian
                @Damian no prob. im learning from reading and asking?
                • X Offline
                  xeroxu
                  And again after two days the mirror did what he wants . I was nearly at that Point to throw all away and start fom beginning. Baut then i tried a thing , I disabled Bluetooth AND WLAN. And did it that way:
                  //sudo nano /etc/modprobe.d/raspi-blacklist.conf
                  blacklist brcmfmac
                  blacklist brcmutil
                  blacklist cfg80211
                  blacklist rfkill
                  blacklist btbcm
                  blacklist hci_uart
                  And after that a Reboot and
                  //sudo systemctl disable hciuart
                  and another reboot .
                  This works, I hope longer then 2 Days ;)
                  Now I have to work with the Ethernetport and gonna try it with an USB Wlan Dongle
