    Not again PIR
    10 Posts 2 Posters 4.7k Views 2 Watching
    • X Offline
      xeroxu
      @Damian Thank you, now I got me a Ferrit Bead but it still dont not work. Maybe my coding or my cabling is wrong.
      		module: 'MMM-PIR-Sensor',
      	sensorPIN: 22,
                                      powerSaving: true
      • X Offline
        xeroxu
        Now that I deleted and reinstalled the module a new problem shows up . After I put the code In my config.js the Monitor stays black after the reboot. I testet the PIR its not broken.
        • X Offline
          xeroxu
          Problem solved :)
            Damian @xeroxu
            @xeroxu
            How did you manage the fix what was wrong? thank you
            • X Offline
              xeroxu
              @Damian I did after i checked the PIR a new npm install in the MM-PIR-Sensor Folder and changed the Sensor Pin to 25 (its the GPIO PIN) wrong thinking thats why I am a Noob ;)
                Damian
                @xeroxu said in Not again PIR:
                Me too but i learn here by reading everything and try to understand better. thank you for reply it will help me too
                X 1 Reply Last reply Reply Quote 0
                • X Offline
                  xeroxu @Damian
                  @Damian no prob. im learning from reading and asking?
                  • X Offline
                    xeroxu
                    And again after two days the mirror did what he wants . I was nearly at that Point to throw all away and start fom beginning. Baut then i tried a thing , I disabled Bluetooth AND WLAN. And did it that way:
                    //sudo nano /etc/modprobe.d/raspi-blacklist.conf
                    blacklist brcmfmac
                    blacklist brcmutil
                    blacklist cfg80211
                    blacklist rfkill
                    blacklist btbcm
                    blacklist hci_uart
                    And after that a Reboot and
                    //sudo systemctl disable hciuart
                    and another reboot .
                    This works, I hope longer then 2 Days ;)
                    Now I have to work with the Ethernetport and gonna try it with an USB Wlan Dongle
