    MMM-Gestures
    3 Posts 2 Posters 2.6k Views 2 Watching
      Aly
      Hey @thobach,
      I have problems with your gestures module for the APDS-9960 Sensor.
      Here is the log data:
      /home/pi/.pm2/logs/gestures-error-1.log last 10 lines:
      1|gestures |     at TCP.onread (net.js:568:26)
      1|gestures | DEPRECATION: Please use `require('serialport')` instead of `require('serialport').SerialPort`
      1|gestures | events.js:160
      1|gestures |       throw er; // Unhandled 'error' event
      1|gestures |       ^
      1|gestures |
      1|gestures | Error: read ECONNRESET
      1|gestures |     at exports._errnoException (util.js:1018:11)
      /home/pi/.pm2/logs/gestures-out-1.log last 10 lines:
      1|gestures | Connection closed
      1|gestures | Sat Jun 03 2017 13:02:17 GMT+0200 (CEST): exec error: Error: Command failed: ls /dev/ttyACM*
      1|gestures | ls: Zugriff auf /dev/ttyACM* nicht möglich: Datei oder Verzeichnis nicht gefunden
      1|gestures |
      1|gestures | New connection from client established
      1|gestures | Received MMM-Gestures client registered to WebSocket server
      1|gestures | Sat Jun 03 2017 13:56:40 GMT+0200 (CEST): exec error: Error: Command failed: ls /dev/ttyACM*
      1|gestures |
      I get gestures via serial monitor in Arduino IDE - so the sensor is correctly connected. I think there is a problem with the connection over USB -gestures.js hasn’t a connection with the arduino. (ttyACM)
      I hope you can help me :)
      Thanks in advance!
      Aly
      • T Offline
        Tobi91
        I receive similar error messages and can´t find the problem. Have you figured out what your problem was? If so could you please let me know.
        Thanks in advance.
        Tobias
          Aly @Tobi91
          @Tobi91
          Hey Tobi,
          no I am sry …
          Aly
