    Analog + Digital Clock module
    38 Posts 5 Posters 50.5k Views 5 Watching
    • K Offline
      Kevin
      Looking for some help with implementing an analog clock next to (left of) the standard digital watch.
      So is someone intrested in helping me “convert” this moments js script to module and make an impementation of it to the standard clock.js? http://codepen.io/Wardee-IDUK/pen/XmMvGK
      With a end result similar to:
      alt text
      • N Offline
        nobita @Kevin
        @Kevin you can convert to module like default module,because I don’t unstand in css,js
        • MichMichM Offline
          MichMich
          I love the idea of adding a analog clock. If you manage to add it, and make it configurable, feel free to send a pull request to the default module.
          • K Offline
            KirAsh4 Moderator
            I’m mildly curious, @Kevin, why would you want both an analog and a digital clock displayed at the same time? I’d rather think someone would want one or the other, but maybe I’m missing something in the grand scheme of things here … like making sure both parallel universes are running on the same time. :)
            • K Offline
              KirAsh4 Moderator
              a) what comes before ALPHA, or BETA? whatever it is, that’s the state of the code
              b) at the moment it’s a separate module, will see about merging it with the current (default) clock
              • K Offline
                Kevin
                Cool, looking good.
                Hehe, right now it’s purely cosmetic with both analog and digital. Looking forward to the beta, delta, omega versions :)
                • K Offline
                  KirAsh4 Moderator
                  Myah, found a few bugs in both the JS and CSS, which are now fixed. (Also found a conflict with same name CSS files across different modules.) Tomorrow I’ll start working on incorporating it with the default one, and see how to make it work so both can be displayed, or one of them while allowing for everything else to reflow gracefully. Adding some config features at the moment … which means I get to play a bit:
                  • K Offline
                    Kevin
                    Fantastic! Looks great. Would be nice if you can ajust the placement of the analog dail, if you manage to implement it to the original clock script.
                    • K Offline
                      KirAsh4 Moderator
                      Adjust placement?
                      • K Offline
                        Kevin
                        ex. right of, left of, over or under the digital time…
                        • K Offline
                          KirAsh4 Moderator
                          Oh that … yeah that will need to be worked out once merged with the other. The current thought process is:
                          displayType: "analog" || "digital" || "both",
                          analogPlacement: "top" || "right" || " bottom" || "left",
                          analogFace: "face-001" || "face-N",
                          There’s likely to be (more) changes/additions as well.
                          • K Offline
                            KirAsh4 Moderator
                            Digital or Analog
                            Both: Analog “top” or “bottom”
                            Both: Analog “left” or “right”
                            Other options include:
                            • ability to change the face of the analog clock
                            • ability to change the size of the analog clock
                            Does that about cover it @Kevin? :)
                            • K Offline
                              KirAsh4 Moderator
                              By the way, there are a few more options being added, specific to the analog clock. While I like my “second” hand to be red, the default will be gray, but I’ll make a config option so people can change its color to something else.
                              I’m also going to have it take into account the 'config.displaySeconds' options.
                              • K Offline
                                KirAsh4 Moderator
                                Also, @MichMich, if you have other requests or comments before I create a PR, now’s the time.
                                • MichMichM Offline
                                  MichMich
                                  Is the red color default? I’d like all the default modules to be B/W…
                                  • MichMichM Offline
                                    MichMich
                                    Very Nice Work By the way! :)
                                    • K Offline
                                      Kevin
                                      Very nice work, you’re the best, thanks a million for the great work.
                                      I think it covers my need right now.
                                      • K Offline
                                        KirAsh4 Moderator @MichMich
                                        @MichMich, read the post above yours … default is gray, not red. A config option will let the user set it to whatever color they want.
                                        • K Offline
                                          KirAsh4 Moderator
                                          Ok, I checked in a PR with the new addition. Current changed/added options in addition the ones already present are:
                                          displayType: 'digital',  // options are: 'digital', 'analog', or 'both'
                                          analogSize: '200px',     // This defines how large you want the analog clock to be
                                          analogFace: 'simple',    // options are: 'simple', 'none', or 'face-###' where ### is a value between
        // 001 to 012, inclusive. The 'simple' options displays a simple border, 'none' is no border,
        // and the 'face-###' ones are SVG images that can be used as the face for the clock
                                          analogPlacement: 'bottom', // options are: 'top', 'right', 'bottom', 'left' This option is applicable only
        // when the displayType is set to 'both' and defined where you want the clock in relation
        // to the digital one
                                          secondsColor: '#888888'. // this defines what color the seconds hand will be. I like mine red ... like wine.
                                          You can see the displays in a prior post.
                                          • K Offline
                                            KirAsh4 Moderator
                                            I forgot to mention this: the clock faces are SVG files, so if you want to put a large analog clock in the middle of your mirror, you can, it will scale beautifully. This is a 600 pixels wide clock using the same SVG file as the smaller one in a previous post.
