    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    Calendar - Use calendar form local file system
    Troubleshooting
    calendar local filesystem
    • coolchip
      coolchip last edited by
      Hello,
      thanks for that wonderfull system with this greate modules.
      I have a question to the module calendar.
      Have some ics files on my local hard drive and I want to see them in the mirror. I tried to add the calender in the configuration als url: “/home/sebastian/mylocalcalendar.ics”
      Unfortunatelly this doesn’t work. Is there a simple way to use local calendars?
      • P
        Phate @coolchip last edited by
        @coolchip
        I think?
        Probably wrong tho.
        Need to use a HTML address to access local.
        Port 8080.
          Shockwave last edited by
          @coolchip , yes this can be done easily by serving it up via http.
          My 2nd calendar entry looks like this:
          symbol: ‘birthday-cake’,
          url: ‘webcal://localhost:8080/modules/birthdays/birthdays.ics’
          That may not be the best location to put it, but I wasn’t able to get it read from outside of /modules.
          • coolchip
            Thank you very much! ❤
