    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 770.8k Views 59 Watching
      airart @sdetweil
      @sdetweil it works ! I am so moved, evidently that was the problem.
      Does CMD remain active how do I leave the MM? fn + f11 reduces to window
      I also noticed some warnings
        sdetweil @airart
        @airart ctrl-c in ther terminal window will stop the active program
        ignore warnings
          matefits71
          Thanks for the tutorial, i’m running magicmirror on a surface pro 4,
          The installation worked perfectly but when i tried to run npm start it throw an error “> DISPLAY=”${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js"
          To bypass the error i edited the package.json by removing the DISPLAY="${DISPLAY:=:0} at the begining, tried npm start and it worked.
          I’m not sure for what is that display option.
            sdetweil @matefits71
            @matefits71 on Linux, the xwindows graphical system writes to a numbered ‘display’ , and there can be multiple.
            windows doesn’t have that. which is why I’ve written to remove that part, and also run the manual npm install in vendors and go ta folders
              angeldchaveza
              $ npm start
              magicmirror@2.16.0 start C:\Users\Tecsis\MagicMirror
              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              “DISPLAY” no se reconoce como un comando interno o externo,
              programa o archivo por lotes ejecutable.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.16.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.16.0 start script.
              npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T01_57_52_304Z-debug.log
                angeldchaveza @angeldchaveza
                @angeldchaveza .
                im delete display of "matefits71 " error logs view
                1 verbose cli [
                1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                1 verbose cli ‘start’
                1 verbose cli ]
                2 info using npm@6.14.14
                3 info using node@v14.17.5
                4 verbose stack Error: missing script: start
                4 verbose stack at run (C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:155:19)
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:63:5
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:116:5
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:436:5
                4 verbose stack at checkBinReferences_ (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:391:45)
                4 verbose stack at final (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:434:3)
                4 verbose stack at then (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:161:5)
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:382:12
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:123:16
                4 verbose stack at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:73:3)
                5 verbose cwd C:\Users\Tecsis\MagicMirror
                6 verbose Windows_NT 10.0.19041
                7 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                8 verbose node v14.17.5
                9 verbose npm v6.14.14
                10 error missing script: start
                11 verbose exit [ 1, true ]
                  sdetweil @angeldchaveza
                  @angeldchaveza u are on windows. there are extra steps for windows.
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
                    angeldchaveza @sdetweil
                    @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                    these were the steps i followed
                      @angeldchaveza yes, but they changed.
                      my link has the updated steps
                        angeldchaveza
                        "Installing fonts …
                        "MagicMirror installation finished successfully!
                        magicmirror@2.16.0 prepare C:\Users\Tecsis\magicmirror
                        [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                        husky - Git hooks installed
                        npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                        npm WARN magicmirror@2.16.0 scripts[‘server’] should probably be scripts[‘start’].
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules\fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                        audited 923 packages in 21.766s
                        110 packages are looking for funding
                        run npm fund for details
                        found 0 vulnerabilities
                        Tecsis@DESKTOP-FGU3JGC MINGW64 ~/magicmirror (master)
                        $ npm start
                        npm ERR! missing script: start
                        npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T02_53_44_514Z-debug.log
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 32
                        • 33
                        • 21 / 33
