    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 772.8k Views 59 Watching
      sdetweil @airart
      @airart did u try to install electron?
      cd ~/MagicMirror
      npm install electron@11.3.0
      so we can see the error, if any
      A 2 Replies Last reply Reply Quote 0
        airart @sdetweil
        @sdetweil yes
        C:\Users\gizmo\MagicMirror>npm install  electron@11.3.0  --loglevel=verbose
        npm verb cli [
        npm verb cli   'C:\\Program Files\\nodejs\\node.exe',
        npm verb cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
        npm verb cli   'install',
        npm verb cli   'electron@11.3.0',
        npm verb cli   '--loglevel=verbose'
        n................ecc
          airart @sdetweil
          @sdetweil i try to restore original package.js and this show me a new log…
          0 verbose cli [
          0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
          0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
          0 verbose cli   'start'
          0 verbose cli ]
          1 info using npm@7.14.0
          2 info using node@v14.17.0
          3 timing npm:load:whichnode Completed in 8ms
          4 timing config:load:defaults Completed in 10ms
          5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 15ms
          6 timing config:load:builtin Completed in 15ms
          7 timing config:load:cli Completed in 8ms
          8 timing config:load:env Completed in 3ms
          9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 1ms
          10 timing config:load:project Completed in 4ms
          11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
          12 timing config:load:user Completed in 1ms
          13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
          14 timing config:load:global Completed in 1ms
          15 timing config:load:validate Completed in 1ms
          16 timing config:load:credentials Completed in 5ms
          17 timing config:load:setEnvs Completed in 4ms
          18 timing config:load Completed in 53ms
          19 timing npm:load:configload Completed in 54ms
          20 timing npm:load:setTitle Completed in 1ms
          21 timing npm:load:setupLog Completed in 13ms
          22 timing npm:load:cleanupLog Completed in 14ms
          23 timing npm:load:configScope Completed in 0ms
          24 timing npm:load:projectScope Completed in 2ms
          25 timing npm:load Completed in 96ms
          26 timing config:load:flatten Completed in 15ms
          27 timing command:run-script Completed in 3ms
          28 timing command:start Completed in 57ms
          29 verbose stack Error: ENOENT: no such file or directory, open 'C:\Users\gizmo\MagicMirror\package.json'
          30 verbose cwd C:\Users\gizmo\MagicMirror
          31 verbose Windows_NT 10.0.18362
          32 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "start"
          33 verbose node v14.17.0
          34 verbose npm  v7.14.0
          35 error code ENOENT
          36 error syscall open
          37 error path C:\Users\gizmo\MagicMirror/package.json
          38 error errno -4058
          39 error enoent ENOENT: no such file or directory, open 'C:\Users\gizmo\MagicMirror\package.json'
          40 error enoent This is related to npm not being able to find a file.
          41 verbose exit -4058
            airart
            nothing to do, it doesn’t seem to find the electron file and folders
              sdetweil @airart
              @airart i don’t understand, I installed on windows 10 without trouble… but it was npm v6.
              I just installed and used npm 7.14…
              I had to use the full path to electron
              here is my package.json start line
              "start": "/Users/sdetw/MagicMirror/node_modules/.bin/electron js/electron.js",
              this is due to a change in npm… my prior instance will not start now without the full path
              S A 2 Replies Last reply Reply Quote 0
                this is because npm 7.14 is trying to launch from the MagicMirror folder instead of the module folder…
                  airart @sdetweil
                  @sdetweil can i install npm v6 ?
                    sdetweil @airart
                    @airart yes,
                    npm install -g npm@6.14.0
                    after this completes
                    cd MagicMirror
                    rd /s/q node_modules
                    npm install
                      airart @sdetweil
                      @sdetweil in which folder it should be installed
                        sdetweil @airart
                        @airart -g means global
                        • 18
                        • 19
                        • 20
                        • 21
                        • 22
                        • 32
                        • 33
                        • 20 / 33
