    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 772.4k Views 59 Watching
      sdetweil @airart
      @airart sorry, typo
      –only=prod
        airart @sdetweil
        @sdetweil ok done , but no log is generated
        npm start
        same errors :-(
          sdetweil @airart
          @airart there is always a log
          in the users home folder .npm/logs
          I will recheck my windows env too
          npm install --loglevel verbose
          should write a file in the local folder
          npm-debug.log
          when I start my MM i get
          C:\Users\sdetw\MagicMirror>npm start
          > magicmirror@2.15.0 start C:\Users\sdetw\MagicMirror
          > electron js/electron.js
          [28.05.2021 09:25.27.486] [LOG]   Starting MagicMirror: v2.15.0
            airart @sdetweil
            @sdetweil i try to find this .log but no one is generating … i search in all of my hdd …
            when i type npm start
            C:\Users\gizmo\MagicMirror>npm start
            > node_modules/.bin/electron js/electron.js
            "node_modules" non è riconosciuto come comando interno o esterno,
             un programma eseguibile o un file batch.
            and there’s no electron js FOLDER in .bin FOLDER
              sdetweil @airart
              @airart do again
                airart @sdetweil
                @sdetweil nope pal , nothing …
                no log
                no start
                where is your log ?
                  sdetweil @airart
                  @airart man I hate this stuff changing all the time
                  do this
                  npm install --only=prod --loglevel verbose >somefile.txt 2>&1
                  then the install info is in somefile.txt
                    airart @sdetweil
                    @sdetweil here !
                    npm verb cli [
                    npm verb cli   'C:\\Program Files\\nodejs\\node.exe',
                    npm verb cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                    npm verb cli   'install',
                    npm verb cli   '--only=prod',
                    npm verb cli   '--loglevel',
                    npm verb cli   'verbose'
                    npm verb cli ]
                    npm info using npm@7.14.0
                    npm info using node@v14.17.0
                    npm timing npm:load:whichnode Completed in 8ms
                    npm timing config:load:defaults Completed in 10ms
                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 16ms
                    npm timing config:load:builtin Completed in 16ms
                    npm verb config only Use `--omit=dev` to omit dev dependencies from the install.
                    npm timing config:load:cli Completed in 11ms
                    npm timing config:load:env Completed in 2ms
                    npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                    npm timing config:load:project Completed in 5ms
                    npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                    npm timing config:load:user Completed in 2ms
                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                    npm timing config:load:global Completed in 1ms
                    npm timing config:load:validate Completed in 2ms
                    npm timing config:load:credentials Completed in 7ms
                    npm timing config:load:setEnvs Completed in 5ms
                    npm timing config:load Completed in 64ms
                    npm timing npm:load:configload Completed in 65ms
                    npm timing npm:load:setTitle Completed in 1ms
                    npm timing npm:load:setupLog Completed in 5ms
                    npm timing npm:load:cleanupLog Completed in 14ms
                    npm timing npm:load:configScope Completed in 0ms
                    npm timing npm:load:projectScope Completed in 5ms
                    npm timing npm:load Completed in 127ms
                    npm timing config:load:flatten Completed in 16ms
                    npm timing arborist:ctor Completed in 4ms
                    npm timing idealTree:init Completed in 2669ms
                    npm timing idealTree:userRequests Completed in 1ms
                    npm timing idealTree:#root Completed in 2ms
                    npm timing idealTree:buildDeps Completed in 9ms
                    npm timing idealTree:fixDepFlags Completed in 1ms
                    npm timing idealTree Completed in 2750ms
                    npm timing arborist:ctor Completed in 1ms
                    npm timing reify:loadTrees Completed in 5000ms
                    npm timing reify:diffTrees Completed in 162ms
                    npm timing reify:retireShallow Completed in 1ms
                    npm timing reify:createSparse Completed in 5ms
                    npm timing reify:trashOmits Completed in 70ms
                    npm timing reify:loadBundles Completed in 0ms
                    npm timing reify:unpack Completed in 189ms
                    npm timing reify:unretire Completed in 1ms
                    npm timing build:queue Completed in 20ms
                    npm timing build:deps Completed in 23ms
                    npm timing build Completed in 23ms
                    npm timing reify:build Completed in 25ms
                    npm http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 7305ms
                    npm timing auditReport:getReport Completed in 7342ms
                    npm timing auditReport:init Completed in 0ms
                    npm timing reify:audit Completed in 7347ms
                    npm timing reify:trash Completed in 7867ms
                    npm timing reify:save Completed in 1634ms
                    npm timing reify Completed in 15363ms
                    > magicmirror@2.15.0 install
                    > echo "Installing vendor files ...
                    > " && cd vendor && npm install --loglevel=error
                    > magicmirror@2.15.0 postinstall
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    npm info it worked if it ends with ok
                    npm verb cli [
                    npm verb cli   'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
                    npm verb cli   'prefix',
                    npm verb cli   '-g'
                    npm verb cli ]
                    npm info using npm@6.14.13
                    npm verb exit [ 0, true ]
                    npm timing npm Completed in 377ms
                    npm info ok
                    npm verb cli [
                    npm verb cli   'run',
                    npm verb cli   'install-fonts'
                    npm verb cli ]
                    npm timing config:load:defaults Completed in 11ms
                    npm timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 15ms
                    npm timing config:load:cli Completed in 8ms
                    npm timing config:load:env Completed in 5ms
                    npm timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 1ms
                    npm timing config:load:file:C:\Users\gizmo\.npmrc Completed in 0ms
                    npm timing config:load:user Completed in 1ms
                    npm timing config:load:validate Completed in 4ms
                    npm timing config:load:credentials Completed in 5ms
                    npm timing config:load:setEnvs Completed in 4ms
                    npm timing config:load Completed in 60ms
                    npm timing npm:load:configload Completed in 62ms
                    npm timing npm:load Completed in 118ms
                    > magicmirror@2.15.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error
                    npm timing command:run-script Completed in 65ms
                    npm verb exit 0
                    npm timing npm Completed in 1407ms
                    npm info ok
                    up to date, audited 331 packages in 21s
                    21 packages are looking for funding
                      run `npm fund` for details
                    found 0 vulnerabilities
                    npm timing command:install Completed in 19769ms
                    npm verb exit 0
                    npm timing npm Completed in 21493ms
                    npm info ok
                      sdetweil @airart
                      @airart well aint that useless… doesn;t say anything about electron
                      lets try this
                      cd MagicMirror
                      npm install  electron@11.3.0  --loglevel=verbose
                        airart @sdetweil
                        @sdetweil is not working
                        	"scripts": {
                        		"start": "node_modules/.bin/electron js/electron.js",
                        		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                        same errors
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 32
                        • 33
                        • 19 / 33
