    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 772.1k Views 59 Watching
      airart @sdetweil
      @sdetweil i edit like this
      "start": "node_modules/.bin/electron js/electron.js",
      A S 2 Replies Last reply Reply Quote 0
        airart @airart
        @airart it say
        “node_modules” non è riconosciuto come come comando interno …
          sdetweil @airart
          @airart mine works like this
          "start": "./node_modules/.bin/electron js/electron.js",
            airart @sdetweil
            @sdetweil seems that in node_modules folder/.bin/ there’s not any electron.js
            i’v also tried with cmd …
              sdetweil @airart
              @airart did you do the npm install?
                airart @sdetweil
                @sdetweil yes i do
                  sdetweil @airart
                  @airart what version of node and npm are installed
                  npm -v
                  node -v
                    airart @sdetweil
                    @sdetweil npm 7.14.0 , node 14.17.0
                      sdetweil @airart
                      @airart interesting
                      ok, lets try to start over that step
                      cd MagicMirror
                      del package-lock.json
                      rd /q/s  node_modules
                      npm install  only=prod
                      we will want the name of the log file when it finishes in case
                        airart @sdetweil
                        @sdetweil only the name ?
                        2021-05-28T12_56_04_242Z-debug
                        0 verbose cli [
                        0 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
                        0 verbose cli   'C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
                        0 verbose cli   'install',
                        0 verbose cli   'only=prod'
                        0 verbose cli ]
                        1 info using npm@7.14.0
                        2 info using node@v14.17.0
                        3 timing npm:load:whichnode Completed in 8ms
                        4 timing config:load:defaults Completed in 9ms
                        5 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\npmrc Completed in 8ms
                        6 timing config:load:builtin Completed in 9ms
                        7 timing config:load:cli Completed in 9ms
                        8 timing config:load:env Completed in 3ms
                        9 timing config:load:file:C:\Users\gizmo\MagicMirror\.npmrc Completed in 2ms
                        10 timing config:load:project Completed in 5ms
                        11 timing config:load:file:C:\Users\gizmo\.npmrc Completed in 1ms
                        12 timing config:load:user Completed in 1ms
                        13 timing config:load:file:C:\Users\gizmo\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                        14 timing config:load:global Completed in 2ms
                        15 timing config:load:validate Completed in 1ms
                        16 timing config:load:credentials Completed in 10ms
                        17 timing config:load:setEnvs Completed in 12ms
                        18 timing config:load Completed in 61ms
                        19 timing npm:load:configload Completed in 61ms
                        20 timing npm:load:setTitle Completed in 3ms
                        21 timing npm:load:setupLog Completed in 11ms
                        22 timing npm:load:cleanupLog Completed in 13ms
                        23 timing npm:load:configScope Completed in 0ms
                        24 timing npm:load:projectScope Completed in 4ms
                        25 timing npm:load Completed in 104ms
                        26 timing config:load:flatten Completed in 20ms
                        27 timing arborist:ctor Completed in 3ms
                        28 timing arborist:ctor Completed in 1ms
                        29 timing idealTree:init Completed in 122ms
                        30 timing idealTree Completed in 150ms
                        31 timing command:install Completed in 234ms
                        32 verbose stack Error: Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                        32 verbose stack     at invalidTagName (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:94:15)
                        32 verbose stack     at fromRegistry (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:299:13)
                        32 verbose stack     at resolve (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:84:12)
                        32 verbose stack     at npa (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\npm-package-arg\npa.js:55:10)
                        32 verbose stack     at C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:474:50
                        32 verbose stack     at Array.map (<anonymous>)
                        32 verbose stack     at Arborist.[add] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:471:28)
                        32 verbose stack     at Arborist.[applyUserRequestsToNode] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:446:23)
                        32 verbose stack     at Arborist.[applyUserRequests] (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:402:43)
                        32 verbose stack     at Arborist.buildIdealTree (C:\Users\gizmo\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:217:37)
                        33 verbose cwd C:\Users\gizmo\MagicMirror
                        34 verbose Windows_NT 10.0.18362
                        35 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\gizmo\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "only=prod"
                        36 verbose node v14.17.0
                        37 verbose npm  v7.14.0
                        38 error code EINVALIDTAGNAME
                        39 error Invalid tag name "only=prod": Tags may not have any characters that encodeURIComponent encodes.
                        40 verbose exit 1
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 32
                        • 33
                        • 18 / 33
