    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 759.8k Views 59 Watching
      mounir @mounir
        sdetweil @mounir
        @mounir is this windows 10, or 11?
        never seen this. installed on windows 11 last week to test
        are u running any other web server apps?
          mounir @sdetweil
          @sdetweil i’m in windows 11 but there is no webserver running
            sdetweil @mounir
            @mounir read this
            https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
            u can change the port in MagicMirror\config\config.js
              mounir @sdetweil
              @sdetweil thank you it works when i’m changing the port in the config.js
                sdetweil
                Note for v ersion 2.18 a little twist
                do
                 npm install --only=prod
                otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                then
                the additional steps are the same
                cd fonts
                npm install
                cd ..\vendor
                npm install
                cd ..
                and edit package.json to change the start line as shown in prior posts
                new info for change of start line in package.json, with node 16
                should be like this (earlier worked with node 14,)
                "start": "node_modules\\.bin\\electron js\\electron.js",
                • P Offline
                  Pearce
                  I went through the installation guide and got this error:
                  $ npm start
                  magicmirror@2.18.0 start
                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  ‘DISPLAY’ is not recognized as an internal or external command,
                  operable program or batch file.
                    sdetweil @Pearce
                    @pearce further up
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                    • N6NGN Offline
                      N6NG
                      Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                      When I try to do the
                      git clone https://github.com/MichMich/MagicMirror.git
                      I get the following error.
                      N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                      $ git clone https://github.com/MichMich/MagicMirror.git
                      fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                      Anyone figured out how to change permissions… sudo isn’t recognized yet.
                      Dennis
                        sdetweil @N6NG
                        @n6ng no mingw,
                        just normal windows prompt
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 32
                        • 33
                        • 23 / 33
