    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 865.0k Views 59 Watching
      mounir @sdetweil
      @sdetweil no i see this
      listen EACCES: permission denied 127.0.0.1:8080
      can you help me fix it
        sdetweil @mounir
        @mounir where do u see that?
        u are installing in cmd terminal window, right?
        not PowerShell
          mounir @mounir
            sdetweil @mounir
            @mounir is this windows 10, or 11?
            never seen this. installed on windows 11 last week to test
            are u running any other web server apps?
              mounir @sdetweil
              @sdetweil i’m in windows 11 but there is no webserver running
                sdetweil @mounir
                @mounir read this
                https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
                u can change the port in MagicMirror\config\config.js
                  mounir @sdetweil
                  @sdetweil thank you it works when i’m changing the port in the config.js
                    Note for v ersion 2.18 a little twist
                    do
                     npm install --only=prod
                    otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                    then
                    the additional steps are the same
                    cd fonts
                    npm install
                    cd ..\vendor
                    npm install
                    cd ..
                    and edit package.json to change the start line as shown in prior posts
                    new info for change of start line in package.json, with node 16
                    should be like this (earlier worked with node 14,)
                    "start": "node_modules\\.bin\\electron js\\electron.js",
                      Pearce
                      I went through the installation guide and got this error:
                      $ npm start
                      magicmirror@2.18.0 start
                      ‘DISPLAY’ is not recognized as an internal or external command,
                      operable program or batch file.
                        sdetweil @Pearce
                        @pearce further up
                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                        • N6NGN Offline
                          N6NG
                          Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                          When I try to do the
                          git clone https://github.com/MichMich/MagicMirror.git
                          I get the following error.
                          N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                          $ git clone https://github.com/MichMich/MagicMirror.git
                          fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                          Anyone figured out how to change permissions… sudo isn’t recognized yet.
                          Dennis
                            sdetweil @N6NG
                            @n6ng no mingw,
                            just normal windows prompt
                            • swvalentiS Offline
                              swvalenti Project Sponsor
                              @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
                              Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
                              main.js:481 Initializing MagicMirror.
                              translator.js:128 Loading core translation file: translations/en.json
                              translator.js:146 Loading core translation fallback file: translations/en.json
                              loader.js:184 Load script: modules/default/alert/alert.js
                              module.js:509 Module registered: alert
                              loader.js:155 Bootstrapping module: alert
                              loader.js:184 Load script: modules/default/alert/notificationFx.js
                              loader.js:160 Scripts loaded for: alert
                              loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                              loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
                              loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
                              loader.js:162 Styles loaded for: alert
                              translator.js:107 alert - Load translationfalse: translations/en.json
                              translator.js:107 alert - Load translation fallback: translations/bg.json
                              loader.js:164 Translations loaded for: alert
                              loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
                              module.js:509 Module registered: updatenotification
                              loader.js:155 Bootstrapping module: updatenotification
                              loader.js:160 Scripts loaded for: updatenotification
                              loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
                              loader.js:162 Styles loaded for: updatenotification
                              loader.js:164 Translations loaded for: updatenotification
                              loader.js:184 Load script: modules/default/clock/clock.js
                              module.js:509 Module registered: clock
                              loader.js:155 Bootstrapping module: clock
                              loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                              loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                              loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                              loader.js:160 Scripts loaded for: clock
                              loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                              loader.js:162 Styles loaded for: clock
                              loader.js:164 Translations loaded for: clock
                              loader.js:184 Load script: modules/default/calendar/calendar.js
                              module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
                              module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                                  at cmpVersions (module.js:525)
                                  at Function.Module.register (module.js:502)
                                  at calendar.js:9
                              loader.js:184 Load script: modules/default/compliments/compliments.js
                              module.js:509 Module registered: compliments
                              loader.js:155 Bootstrapping module: compliments
                              loader.js:244 File already loaded: moment.js
                              loader.js:160 Scripts loaded for: compliments
                              loader.js:162 Styles loaded for: compliments
                              loader.js:164 Translations loaded for: compliments
                              loader.js:184 Load script: modules/default/weather/weather.js
                              module.js:509 Module registered: weather
                              loader.js:155 Bootstrapping module: weather
                              loader.js:184 Load script: modules/default/weather/weatherprovider.js
                              loader.js:184 Load script: modules/default/weather/weatherobject.js
                              loader.js:244 File already loaded: suncalc.js
                              loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
                              loader.js:160 Scripts loaded for: weather
                              loader.js:244 File already loaded: font-awesome.css
                              loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                              loader.js:203 Load stylesheet: modules/default/weather/weather.css
                              loader.js:162 Styles loaded for: weather
                              loader.js:164 Translations loaded for: weather
                              loader.js:184 Load script: modules/MMM-News/MMM-News.js
                              module.js:509 Module registered: MMM-News
                              loader.js:155 Bootstrapping module: MMM-News
                              loader.js:160 Scripts loaded for: MMM-News
                              loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
                              loader.js:162 Styles loaded for: MMM-News
                              loader.js:164 Translations loaded for: MMM-News
                              loader.js:203 Load stylesheet: css/custom.css
                              alert.js:47 Starting module: alert
                              updatenotification.js:18 Starting module: updatenotification
                              clock.js:48 Starting module: clock
                              compliments.js:38 Starting module: compliments
                              weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                              weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                              main.js:499 All modules started!
                              module.js:94 Template render error: (updatenotification.njk)
                                EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                                  at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                                  at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                                  at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                                  at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
                              (anonymous) @ module.js:94
                              module.js:94 Template render error: (current.njk)
                              weather.js:149 New weather information available.
                              swvalentiS S 2 Replies Last reply Reply Quote 0
                                swvalenti Project Sponsor @swvalenti
                                Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                                  I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                                    sdetweil @swvalenti
                                    @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                                    cd vendor
                                    npm install
                                    cd ..
                                    cd fonts
                                    npm install
                                    cd ..
                                    now u can start
                                      sdetweil @swvalenti
                                      @swvalenti black screen
                                      see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                      swvalentiS 1 Reply Last reply Reply Quote 0
                                        swvalenti Project Sponsor @sdetweil
                                        @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
                                          sdetweil @swvalenti
                                          @swvalenti where did u install the extra modules?
                                          same place as on linux
                                          MagicMirror/modules
                                          right??
                                            @sdetweil also how do you not install under mingw could that be the issue
                                            S swvalentiS 3 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
