    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
      mounir @sdetweil
      @sdetweil thank you it works when i’m changing the port in the config.js
        Note for v ersion 2.18 a little twist
        do
         npm install --only=prod
        otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
        then
        the additional steps are the same
        cd fonts
        npm install
        cd ..\vendor
        npm install
        cd ..
        and edit package.json to change the start line as shown in prior posts
        new info for change of start line in package.json, with node 16
        should be like this (earlier worked with node 14,)
        "start": "node_modules\\.bin\\electron js\\electron.js",
          Pearce
          I went through the installation guide and got this error:
          $ npm start
          magicmirror@2.18.0 start
          ‘DISPLAY’ is not recognized as an internal or external command,
          operable program or batch file.
            sdetweil @Pearce
            @pearce further up
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
            • N6NGN
              N6NG
              Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
              When I try to do the
              git clone https://github.com/MichMich/MagicMirror.git
              I get the following error.
              N6NG@Main-Computer-in-Ham-Shack MINGW64 /
              $ git clone https://github.com/MichMich/MagicMirror.git
              fatal: could not create work tree dir ‘MagicMirror’: Permission denied
              Anyone figured out how to change permissions… sudo isn’t recognized yet.
              Dennis
                sdetweil @N6NG
                @n6ng no mingw,
                just normal windows prompt
                • swvalentiS
                  swvalenti Project Sponsor
                  @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
                  Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
                  main.js:481 Initializing MagicMirror.
                  translator.js:128 Loading core translation file: translations/en.json
                  translator.js:146 Loading core translation fallback file: translations/en.json
                  loader.js:184 Load script: modules/default/alert/alert.js
                  module.js:509 Module registered: alert
                  loader.js:155 Bootstrapping module: alert
                  loader.js:184 Load script: modules/default/alert/notificationFx.js
                  loader.js:160 Scripts loaded for: alert
                  loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                  loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
                  loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
                  loader.js:162 Styles loaded for: alert
                  translator.js:107 alert - Load translationfalse: translations/en.json
                  translator.js:107 alert - Load translation fallback: translations/bg.json
                  loader.js:164 Translations loaded for: alert
                  loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
                  module.js:509 Module registered: updatenotification
                  loader.js:155 Bootstrapping module: updatenotification
                  loader.js:160 Scripts loaded for: updatenotification
                  loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
                  loader.js:162 Styles loaded for: updatenotification
                  loader.js:164 Translations loaded for: updatenotification
                  loader.js:184 Load script: modules/default/clock/clock.js
                  module.js:509 Module registered: clock
                  loader.js:155 Bootstrapping module: clock
                  loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                  loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                  loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                  loader.js:160 Scripts loaded for: clock
                  loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                  loader.js:162 Styles loaded for: clock
                  loader.js:164 Translations loaded for: clock
                  loader.js:184 Load script: modules/default/calendar/calendar.js
                  module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
                  module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                      at cmpVersions (module.js:525)
                      at Function.Module.register (module.js:502)
                      at calendar.js:9
                  loader.js:184 Load script: modules/default/compliments/compliments.js
                  module.js:509 Module registered: compliments
                  loader.js:155 Bootstrapping module: compliments
                  loader.js:244 File already loaded: moment.js
                  loader.js:160 Scripts loaded for: compliments
                  loader.js:162 Styles loaded for: compliments
                  loader.js:164 Translations loaded for: compliments
                  loader.js:184 Load script: modules/default/weather/weather.js
                  module.js:509 Module registered: weather
                  loader.js:155 Bootstrapping module: weather
                  loader.js:184 Load script: modules/default/weather/weatherprovider.js
                  loader.js:184 Load script: modules/default/weather/weatherobject.js
                  loader.js:244 File already loaded: suncalc.js
                  loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
                  loader.js:160 Scripts loaded for: weather
                  loader.js:244 File already loaded: font-awesome.css
                  loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                  loader.js:203 Load stylesheet: modules/default/weather/weather.css
                  loader.js:162 Styles loaded for: weather
                  loader.js:164 Translations loaded for: weather
                  loader.js:184 Load script: modules/MMM-News/MMM-News.js
                  module.js:509 Module registered: MMM-News
                  loader.js:155 Bootstrapping module: MMM-News
                  loader.js:160 Scripts loaded for: MMM-News
                  loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
                  loader.js:162 Styles loaded for: MMM-News
                  loader.js:164 Translations loaded for: MMM-News
                  loader.js:203 Load stylesheet: css/custom.css
                  alert.js:47 Starting module: alert
                  updatenotification.js:18 Starting module: updatenotification
                  clock.js:48 Starting module: clock
                  compliments.js:38 Starting module: compliments
                  weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                  weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                  main.js:499 All modules started!
                  module.js:94 Template render error: (updatenotification.njk)
                    EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                      at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                      at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                      at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                      at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
                  (anonymous) @ module.js:94
                  module.js:94 Template render error: (current.njk)
                  weather.js:149 New weather information available.
                  swvalentiS S 2 Replies Last reply
                  • swvalentiS
                    swvalenti Project Sponsor @swvalenti
                    Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                    • swvalentiS
                      I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                        sdetweil @swvalenti
                        @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                        cd vendor
                        npm install
                        cd ..
                        cd fonts
                        npm install
                        cd ..
                        now u can start
                          sdetweil @swvalenti
                          @swvalenti black screen
                          see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                          swvalentiS 1 Reply Last reply
                          • swvalentiS
                            swvalenti Project Sponsor @sdetweil
                            @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
                              sdetweil @swvalenti
                              @swvalenti where did u install the extra modules?
                              same place as on linux
                              MagicMirror/modules
                              right??
                              • swvalentiS
                                @sdetweil also how do you not install under mingw could that be the issue
                                S swvalentiS 3 Replies Last reply
                                  sdetweil @swvalenti
                                  @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                  open a Windows cmd.exe session and do all the commands there…
                                  • swvalentiS
                                    there just the default modules in MagicMirror but others don’t show at all like MMM-PGA but fine on a pi
                                    • swvalentiS
                                      Ok I did that but I’ll try again
                                      S swvalentiS 2 Replies Last reply
                                        sdetweil @swvalenti
                                        i don’t know what “don’t show” means
                                        did u edit the config.js
                                        only a vew modules don’t work on Windows (snowboy voice driven for example)
                                          sdetweil @swvalenti
                                          note that u have to run the extra install steps manually too
                                          • swvalentiS
                                            the position where the modules are supposed to show only a black black screen rest of modules work fine
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
