    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti black screen
      see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
      swvalentiS 1 Reply Last reply
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
          sdetweil @swvalenti
          @swvalenti where did u install the extra modules?
          same place as on linux
          MagicMirror/modules
          right??
          • swvalentiS
            @sdetweil also how do you not install under mingw could that be the issue
            S swvalentiS 3 Replies Last reply
              sdetweil @swvalenti
              @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              open a Windows cmd.exe session and do all the commands there…
              • swvalentiS
                swvalenti Project Sponsor @swvalenti
                there just the default modules in MagicMirror but others don’t show at all like MMM-PGA but fine on a pi
                • swvalentiS
                  Ok I did that but I’ll try again
                  S swvalentiS 2 Replies Last reply
                    sdetweil @swvalenti
                    i don’t know what “don’t show” means
                    did u edit the config.js
                    only a vew modules don’t work on Windows (snowboy voice driven for example)
                      sdetweil @swvalenti
                      note that u have to run the extra install steps manually too
                      • swvalentiS
                        the position where the modules are supposed to show only a black black screen rest of modules work fine
                          sdetweil @swvalenti
                          maybe fonts or the nunjucks… (from vendor folder)
                          • swvalentiS
                            @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                            I did the fonts but no clue what nunjucks is and how to fix it when I googled it I only got pictures of nunjucks
                              sdetweil @swvalenti
                              @swvalenti nunjuks is the web content templating code, which some of the modules use (it generates the web content from a ‘form’ like definition)
                              but that will not be installed if you do not npm install from the MagicMirror/vendor folder
                              • swvalentiS
                                Ok offially at a lost oh well it was worth a shot to try
                                swvalentiS S 2 Replies Last reply
                                • swvalentiS
                                  @sdetweil as an example MMM-PGA shows this in dev
                                  module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                                      at cmpVersions (module.js:525)
                                      at Function.Module.register (module.js:502)
                                      at MMM-PGA.js:9
                                    sdetweil @swvalenti
                                    @swvalenti here are the windows instructions
                                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1647717794843
                                      sdetweil @swvalenti
                                      @swvalenti mmm-pga… looks like you didn’t complete the MM install process on windows
                                      • swvalentiS
                                        I followed the complete walkthrough but I can’t diagnose what I did wrong if you say that I did. Sorry to be a bother Sam
                                          sdetweil @swvalenti
                                          @swvalenti I just install the module on my Windows MM 2.18 instance without trouble…
                                          it was missing a library , per the back screen link… once I fixed that the module came up without issues
                                          • swvalentiS
                                            Well doesn’t surprise me there! HA thanks for all your work nonetheless
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
