    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      Ok I did that but I’ll try again
      note that u have to run the extra install steps manually too
      • swvalentiS Offline
        swvalenti Project Sponsor @swvalenti
        @sdetweil also how do you not install under mingw could that be the issue
        the position where the modules are supposed to show only a black black screen rest of modules work fine
          sdetweil @swvalenti
          maybe fonts or the nunjucks… (from vendor folder)
          swvalentiS 1 Reply Last reply Reply Quote 0
            swvalenti Project Sponsor @sdetweil
            @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            I did the fonts but no clue what nunjucks is and how to fix it when I googled it I only got pictures of nunjucks
              sdetweil @swvalenti
              @swvalenti nunjuks is the web content templating code, which some of the modules use (it generates the web content from a ‘form’ like definition)
              but that will not be installed if you do not npm install from the MagicMirror/vendor folder
                Ok offially at a lost oh well it was worth a shot to try
                swvalentiS S 2 Replies Last reply Reply Quote 0
                  @sdetweil as an example MMM-PGA shows this in dev
                  module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                      at cmpVersions (module.js:525)
                      at Function.Module.register (module.js:502)
                      at MMM-PGA.js:9
                    sdetweil @swvalenti
                    @swvalenti here are the windows instructions
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1647717794843
                      sdetweil @swvalenti
                      @swvalenti mmm-pga… looks like you didn’t complete the MM install process on windows
                        I followed the complete walkthrough but I can’t diagnose what I did wrong if you say that I did. Sorry to be a bother Sam
                          sdetweil @swvalenti
                          @swvalenti I just install the module on my Windows MM 2.18 instance without trouble…
                          it was missing a library , per the back screen link… once I fixed that the module came up without issues
                            Well doesn’t surprise me there! HA thanks for all your work nonetheless
                              sdetweil @swvalenti
                              @swvalenti the module is missing ‘request’
                                npm install request in the MM folder?
                                  sdetweil @swvalenti
                                  @swvalenti no,. read the 1st post of the link I posted for black screen
                                    ok we are getting somewhere pga now works, openweather forecast still doesn’t work no error in console
                                      sdetweil @swvalenti
                                      sorry, no idea there
                                        sam whatever you told me to not which step I got it all working. Only issue now is two modules are not centered correctly even when using top_center…how or if you can use css for that?
                                          sdetweil @swvalenti
                                          maybe… depends on the module
                                          see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1647717794860
                                            @sdetweil any ideas on this one just showed up…It asked me that npm needed major update now it doesn’t work
                                            C:\Users\Svale\MagicMirror>npm start
                                            > magicmirror@2.18.0 start
                                            > ./node_modules/.bin/electron js/electron.js
                                            '.' is not recognized as an internal or external command,
                                            operable program or batch file.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
