    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @swvalenti
      @sdetweil as an example MMM-PGA shows this in dev
      module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
          at cmpVersions (module.js:525)
          at Function.Module.register (module.js:502)
          at MMM-PGA.js:9
        sdetweil @swvalenti
        @swvalenti here are the windows instructions
        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1647717794843
          sdetweil @swvalenti
          @swvalenti mmm-pga… looks like you didn’t complete the MM install process on windows
          swvalentiS 1 Reply Last reply Reply Quote 0
            swvalenti Project Sponsor @sdetweil
            @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            I followed the complete walkthrough but I can’t diagnose what I did wrong if you say that I did. Sorry to be a bother Sam
              sdetweil @swvalenti
              @swvalenti I just install the module on my Windows MM 2.18 instance without trouble…
              it was missing a library , per the back screen link… once I fixed that the module came up without issues
                Well doesn’t surprise me there! HA thanks for all your work nonetheless
                  sdetweil @swvalenti
                  @swvalenti the module is missing ‘request’
                    npm install request in the MM folder?
                      sdetweil @swvalenti
                      @swvalenti no,. read the 1st post of the link I posted for black screen
                        ok we are getting somewhere pga now works, openweather forecast still doesn’t work no error in console
                          sdetweil @swvalenti
                          @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                          sorry, no idea there
                            sam whatever you told me to not which step I got it all working. Only issue now is two modules are not centered correctly even when using top_center…how or if you can use css for that?
                              sdetweil @swvalenti
                              maybe… depends on the module
                              see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1647717794860
                                @sdetweil any ideas on this one just showed up…It asked me that npm needed major update now it doesn’t work
                                C:\Users\Svale\MagicMirror>npm start
                                > magicmirror@2.18.0 start
                                > ./node_modules/.bin/electron js/electron.js
                                '.' is not recognized as an internal or external command,
                                operable program or batch file.
                                  sdetweil @swvalenti
                                  ./node_modules
                                  yes, you cannot have the ./ in front… windows doesn’t understand that …
                                  read the instructions again
                                    sdetweil @swvalenti
                                    @swvalenti you shouldn’t update things unless u know why you are doing it…
                                    we test with certain runtimes and release every 3 months
                                      ./node_modules
                                      now I get this error…will never update again lesson learned
                                      > magicmirror@2.18.0 start C:\Users\Svale\MagicMirror
                                      'electron' is not recognized as an internal or external command,
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! magicmirror@2.18.0 start: `electron js/electron.js`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.18.0 start script.
                                      npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T21_48_27_176Z-debug.log
                                        sdetweil @swvalenti
                                        @swvalenti come on
                                        remove the display and the leading
                                        "start":"node_modules/.bin/electron js/electron.js",
                                          “start”:“node_modules/.bin/electron js/electron.js”,
                                          I did that sam still doesn’t work sorry to be a bother
                                            sdetweil @swvalenti
                                            @swvalenti and what is the message?
                                            what npm version are u running?
                                            npm -v
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
