    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
      Pearce
      I went through the installation guide and got this error:
      $ npm start
      magicmirror@2.18.0 start
      ‘DISPLAY’ is not recognized as an internal or external command,
      operable program or batch file.
        sdetweil @Pearce
        @pearce further up
        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
        • N6NGN
          N6NG
          Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
          When I try to do the
          git clone https://github.com/MichMich/MagicMirror.git
          I get the following error.
          N6NG@Main-Computer-in-Ham-Shack MINGW64 /
          $ git clone https://github.com/MichMich/MagicMirror.git
          fatal: could not create work tree dir ‘MagicMirror’: Permission denied
          Anyone figured out how to change permissions… sudo isn’t recognized yet.
          Dennis
            sdetweil @N6NG
            @n6ng no mingw,
            just normal windows prompt
            • swvalentiS
              swvalenti Project Sponsor
              @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
              Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
              main.js:481 Initializing MagicMirror.
              translator.js:128 Loading core translation file: translations/en.json
              translator.js:146 Loading core translation fallback file: translations/en.json
              loader.js:184 Load script: modules/default/alert/alert.js
              module.js:509 Module registered: alert
              loader.js:155 Bootstrapping module: alert
              loader.js:184 Load script: modules/default/alert/notificationFx.js
              loader.js:160 Scripts loaded for: alert
              loader.js:203 Load stylesheet: vendor/css/font-awesome.css
              loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
              loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
              loader.js:162 Styles loaded for: alert
              translator.js:107 alert - Load translationfalse: translations/en.json
              translator.js:107 alert - Load translation fallback: translations/bg.json
              loader.js:164 Translations loaded for: alert
              loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
              module.js:509 Module registered: updatenotification
              loader.js:155 Bootstrapping module: updatenotification
              loader.js:160 Scripts loaded for: updatenotification
              loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
              loader.js:162 Styles loaded for: updatenotification
              loader.js:164 Translations loaded for: updatenotification
              loader.js:184 Load script: modules/default/clock/clock.js
              module.js:509 Module registered: clock
              loader.js:155 Bootstrapping module: clock
              loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
              loader.js:160 Scripts loaded for: clock
              loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
              loader.js:162 Styles loaded for: clock
              loader.js:164 Translations loaded for: clock
              loader.js:184 Load script: modules/default/calendar/calendar.js
              module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
              module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                  at cmpVersions (module.js:525)
                  at Function.Module.register (module.js:502)
                  at calendar.js:9
              loader.js:184 Load script: modules/default/compliments/compliments.js
              module.js:509 Module registered: compliments
              loader.js:155 Bootstrapping module: compliments
              loader.js:244 File already loaded: moment.js
              loader.js:160 Scripts loaded for: compliments
              loader.js:162 Styles loaded for: compliments
              loader.js:164 Translations loaded for: compliments
              loader.js:184 Load script: modules/default/weather/weather.js
              module.js:509 Module registered: weather
              loader.js:155 Bootstrapping module: weather
              loader.js:184 Load script: modules/default/weather/weatherprovider.js
              loader.js:184 Load script: modules/default/weather/weatherobject.js
              loader.js:244 File already loaded: suncalc.js
              loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
              loader.js:160 Scripts loaded for: weather
              loader.js:244 File already loaded: font-awesome.css
              loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
              loader.js:203 Load stylesheet: modules/default/weather/weather.css
              loader.js:162 Styles loaded for: weather
              loader.js:164 Translations loaded for: weather
              loader.js:184 Load script: modules/MMM-News/MMM-News.js
              module.js:509 Module registered: MMM-News
              loader.js:155 Bootstrapping module: MMM-News
              loader.js:160 Scripts loaded for: MMM-News
              loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
              loader.js:162 Styles loaded for: MMM-News
              loader.js:164 Translations loaded for: MMM-News
              loader.js:203 Load stylesheet: css/custom.css
              alert.js:47 Starting module: alert
              updatenotification.js:18 Starting module: updatenotification
              clock.js:48 Starting module: clock
              compliments.js:38 Starting module: compliments
              weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
              weatherprovider.js:46 Weather provider: OpenWeatherMap started.
              main.js:499 All modules started!
              module.js:94 Template render error: (updatenotification.njk)
                EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                  at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                  at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                  at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                  at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                  at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
              (anonymous) @ module.js:94
              module.js:94 Template render error: (current.njk)
              weather.js:149 New weather information available.
              swvalentiS S 2 Replies Last reply
              • swvalentiS
                swvalenti Project Sponsor @swvalenti
                Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                • swvalentiS
                  I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                    sdetweil @swvalenti
                    @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                    cd vendor
                    npm install
                    cd ..
                    cd fonts
                    npm install
                    cd ..
                    now u can start
                      sdetweil @swvalenti
                      @swvalenti black screen
                      see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                      swvalentiS 1 Reply Last reply
                      • swvalentiS
                        swvalenti Project Sponsor @sdetweil
                        @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
                          sdetweil @swvalenti
                          @swvalenti where did u install the extra modules?
                          same place as on linux
                          MagicMirror/modules
                          right??
                          • swvalentiS
                            @sdetweil also how do you not install under mingw could that be the issue
                            S swvalentiS 3 Replies Last reply
                              sdetweil @swvalenti
                              @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                              open a Windows cmd.exe session and do all the commands there…
                              • swvalentiS
                                there just the default modules in MagicMirror but others don’t show at all like MMM-PGA but fine on a pi
                                • swvalentiS
                                  Ok I did that but I’ll try again
                                  S swvalentiS 2 Replies Last reply
                                    sdetweil @swvalenti
                                    i don’t know what “don’t show” means
                                    did u edit the config.js
                                    only a vew modules don’t work on Windows (snowboy voice driven for example)
                                      sdetweil @swvalenti
                                      note that u have to run the extra install steps manually too
                                      • swvalentiS
                                        the position where the modules are supposed to show only a black black screen rest of modules work fine
                                          sdetweil @swvalenti
                                          maybe fonts or the nunjucks… (from vendor folder)
                                          • swvalentiS
                                            @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                            I did the fonts but no clue what nunjucks is and how to fix it when I googled it I only got pictures of nunjucks
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
