    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
      sdetweil @KillK
      @killk we are all volunteers here. more folks around in the evenings, weekends. but it’s all volunteer. no commitment to answer any question or solve any problem . asking in multiple places doesn’t get help any faster.
        sdetweil @KillK
        @killk I had no problem
        Win 10, under Vmware
        git clone
        npm install
        and in vendors and fonts
        edit the package.json
        copy the default config.js from the sample
        npm start
          mounir @Mykle1
          @mykle1 how can i resolve this ?
          ‘DISPLAY’ is not recognized as an internal or external command,
          operable program or batch file.
            sdetweil @mounir
            @mounir have to scan further back
            see
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
              mounir @sdetweil
              @sdetweil no i see this
              listen EACCES: permission denied 127.0.0.1:8080
              can you help me fix it
                sdetweil @mounir
                @mounir where do u see that?
                u are installing in cmd terminal window, right?
                not PowerShell
                  mounir @mounir
                    sdetweil @mounir
                    @mounir is this windows 10, or 11?
                    never seen this. installed on windows 11 last week to test
                    are u running any other web server apps?
                      mounir @sdetweil
                      @sdetweil i’m in windows 11 but there is no webserver running
                        sdetweil @mounir
                        @mounir read this
                        https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
                        u can change the port in MagicMirror\config\config.js
                          mounir @sdetweil
                          @sdetweil thank you it works when i’m changing the port in the config.js
                            Note for v ersion 2.18 a little twist
                            do
                             npm install --only=prod
                            otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                            then
                            the additional steps are the same
                            cd fonts
                            npm install
                            cd ..\vendor
                            npm install
                            cd ..
                            and edit package.json to change the start line as shown in prior posts
                            new info for change of start line in package.json, with node 16
                            should be like this (earlier worked with node 14,)
                            "start": "node_modules\\.bin\\electron js\\electron.js",
                              Pearce
                              I went through the installation guide and got this error:
                              $ npm start
                              magicmirror@2.18.0 start
                                sdetweil @Pearce
                                @pearce further up
                                • N6NGN
                                  N6NG
                                  Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                                  When I try to do the
                                  git clone https://github.com/MichMich/MagicMirror.git
                                  I get the following error.
                                  N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                                  $ git clone https://github.com/MichMich/MagicMirror.git
                                  fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                                  Anyone figured out how to change permissions… sudo isn’t recognized yet.
                                  Dennis
                                    sdetweil @N6NG
                                    @n6ng no mingw,
                                    just normal windows prompt
                                    • swvalentiS
                                      swvalenti Project Sponsor
                                      @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
                                      Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
                                      main.js:481 Initializing MagicMirror.
                                      translator.js:128 Loading core translation file: translations/en.json
                                      translator.js:146 Loading core translation fallback file: translations/en.json
                                      loader.js:184 Load script: modules/default/alert/alert.js
                                      module.js:509 Module registered: alert
                                      loader.js:155 Bootstrapping module: alert
                                      loader.js:184 Load script: modules/default/alert/notificationFx.js
                                      loader.js:160 Scripts loaded for: alert
                                      loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                                      loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
                                      loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
                                      loader.js:162 Styles loaded for: alert
                                      translator.js:107 alert - Load translationfalse: translations/en.json
                                      translator.js:107 alert - Load translation fallback: translations/bg.json
                                      loader.js:164 Translations loaded for: alert
                                      loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
                                      module.js:509 Module registered: updatenotification
                                      loader.js:155 Bootstrapping module: updatenotification
                                      loader.js:160 Scripts loaded for: updatenotification
                                      loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
                                      loader.js:162 Styles loaded for: updatenotification
                                      loader.js:164 Translations loaded for: updatenotification
                                      loader.js:184 Load script: modules/default/clock/clock.js
                                      module.js:509 Module registered: clock
                                      loader.js:155 Bootstrapping module: clock
                                      loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                      loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                      loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                                      loader.js:160 Scripts loaded for: clock
                                      loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                                      loader.js:162 Styles loaded for: clock
                                      loader.js:164 Translations loaded for: clock
                                      loader.js:184 Load script: modules/default/calendar/calendar.js
                                      module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
                                      module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                                          at cmpVersions (module.js:525)
                                          at Function.Module.register (module.js:502)
                                          at calendar.js:9
                                      loader.js:184 Load script: modules/default/compliments/compliments.js
                                      module.js:509 Module registered: compliments
                                      loader.js:155 Bootstrapping module: compliments
                                      loader.js:244 File already loaded: moment.js
                                      loader.js:160 Scripts loaded for: compliments
                                      loader.js:162 Styles loaded for: compliments
                                      loader.js:164 Translations loaded for: compliments
                                      loader.js:184 Load script: modules/default/weather/weather.js
                                      module.js:509 Module registered: weather
                                      loader.js:155 Bootstrapping module: weather
                                      loader.js:184 Load script: modules/default/weather/weatherprovider.js
                                      loader.js:184 Load script: modules/default/weather/weatherobject.js
                                      loader.js:244 File already loaded: suncalc.js
                                      loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
                                      loader.js:160 Scripts loaded for: weather
                                      loader.js:244 File already loaded: font-awesome.css
                                      loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                      loader.js:203 Load stylesheet: modules/default/weather/weather.css
                                      loader.js:162 Styles loaded for: weather
                                      loader.js:164 Translations loaded for: weather
                                      loader.js:184 Load script: modules/MMM-News/MMM-News.js
                                      module.js:509 Module registered: MMM-News
                                      loader.js:155 Bootstrapping module: MMM-News
                                      loader.js:160 Scripts loaded for: MMM-News
                                      loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
                                      loader.js:162 Styles loaded for: MMM-News
                                      loader.js:164 Translations loaded for: MMM-News
                                      loader.js:203 Load stylesheet: css/custom.css
                                      alert.js:47 Starting module: alert
                                      updatenotification.js:18 Starting module: updatenotification
                                      clock.js:48 Starting module: clock
                                      compliments.js:38 Starting module: compliments
                                      weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                                      weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                                      main.js:499 All modules started!
                                      module.js:94 Template render error: (updatenotification.njk)
                                        EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                                          at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                                          at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                                          at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                                          at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                                          at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                                          at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                                          at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
                                      (anonymous) @ module.js:94
                                      module.js:94 Template render error: (current.njk)
                                      weather.js:149 New weather information available.
                                      swvalentiS S 2 Replies Last reply Reply Quote 0
                                      • swvalentiS
                                        swvalenti Project Sponsor @swvalenti
                                        Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                                        • swvalentiS
                                          I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                                            sdetweil @swvalenti
                                            @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                                            cd vendor
                                            npm install
                                            cd ..
                                            cd fonts
                                            npm install
                                            cd ..
                                            now u can start
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
