    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.3k Views 59 Watching
    • A
      angeldchaveza
      "Installing fonts …
      "MagicMirror installation finished successfully!
      magicmirror@2.16.0 prepare C:\Users\Tecsis\magicmirror
      [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      husky - Git hooks installed
      npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
      npm WARN magicmirror@2.16.0 scripts[‘server’] should probably be scripts[‘start’].
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules\fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
      audited 923 packages in 21.766s
      110 packages are looking for funding
      run npm fund for details
      found 0 vulnerabilities
      Tecsis@DESKTOP-FGU3JGC MINGW64 ~/magicmirror (master)
      $ npm start
      npm ERR! missing script: start
      npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T02_53_44_514Z-debug.log
        sdetweil @angeldchaveza
        @angeldchaveza do NOT install under
        MINGW64
        just straight windows
        • K
          KillK
          Hi, newby here… I have reinstaled MM in my win 10 laptop… It was working well until the reinstallation…
          I am having an issue, i will try to translate it, cuz my cmd is in spanish…
          magicmirror@2.17.1 start
          node_modules/.bin/electron js/electron.js
          “node_modules” doesn’t recognize it as an internal or external command,
          program or file by executable lot.
          At the same time i have notice, that “.bin” folder doesn’t contain “electron js” folder inside…
          I have had to install manually npm for fonts ans vendor’s folders…
          Please, help me Obi Wan Kenobi…
          mumblebajM S 2 Replies Last reply
          • mumblebajM
            mumblebaj Module Developer @KillK
            @killk You have asked the same question in different posts a few times. This can be seen as spamming,
            K 1 Reply Last reply
            • K
              KillK @mumblebaj
              @mumblebaj oh sorry, i have to delete the other one… I didn’t know it.
                sdetweil @KillK
                @killk we are all volunteers here. more folks around in the evenings, weekends. but it’s all volunteer. no commitment to answer any question or solve any problem . asking in multiple places doesn’t get help any faster.
                  sdetweil @KillK
                  @killk I had no problem
                  Win 10, under Vmware
                  git clone
                  npm install
                  and in vendors and fonts
                  edit the package.json
                  copy the default config.js from the sample
                  npm start
                    mounir @Mykle1
                    @mykle1 how can i resolve this ?
                    ‘DISPLAY’ is not recognized as an internal or external command,
                    operable program or batch file.
                      sdetweil @mounir
                      @mounir have to scan further back
                      see
                      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                        mounir @sdetweil
                        @sdetweil no i see this
                        listen EACCES: permission denied 127.0.0.1:8080
                        can you help me fix it
                        S M 2 Replies Last reply
                          sdetweil @mounir
                          @mounir where do u see that?
                          u are installing in cmd terminal window, right?
                          not PowerShell
                            mounir @mounir
                              sdetweil @mounir
                              @mounir is this windows 10, or 11?
                              never seen this. installed on windows 11 last week to test
                              are u running any other web server apps?
                              M 1 Reply Last reply
                                mounir @sdetweil
                                @sdetweil i’m in windows 11 but there is no webserver running
                                  sdetweil @mounir
                                  @mounir read this
                                  https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
                                  u can change the port in MagicMirror\config\config.js
                                    mounir @sdetweil
                                    @sdetweil thank you it works when i’m changing the port in the config.js
                                      Note for v ersion 2.18 a little twist
                                      do
                                       npm install --only=prod
                                      otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                                      then
                                      the additional steps are the same
                                      cd fonts
                                      npm install
                                      cd ..\vendor
                                      npm install
                                      cd ..
                                      and edit package.json to change the start line as shown in prior posts
                                      new info for change of start line in package.json, with node 16
                                      should be like this (earlier worked with node 14,)
                                      "start": "node_modules\\.bin\\electron js\\electron.js",
                                        Pearce
                                        I went through the installation guide and got this error:
                                        $ npm start
                                        magicmirror@2.18.0 start
                                          sdetweil @Pearce
                                          @pearce further up
                                          • N6NGN
                                            N6NG
                                            Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                                            When I try to do the
                                            git clone https://github.com/MichMich/MagicMirror.git
                                            I get the following error.
                                            N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                                            $ git clone https://github.com/MichMich/MagicMirror.git
                                            fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                                            Anyone figured out how to change permissions… sudo isn’t recognized yet.
                                            Dennis
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
