    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 849.3k Views 59 Watching
      sdetweil @matefits71
      @matefits71 on Linux, the xwindows graphical system writes to a numbered ‘display’ , and there can be multiple.
      windows doesn’t have that. which is why I’ve written to remove that part, and also run the manual npm install in vendors and go ta folders
        angeldchaveza
        $ npm start
        magicmirror@2.16.0 start C:\Users\Tecsis\MagicMirror
        “DISPLAY” no se reconoce como un comando interno o externo,
        programa o archivo por lotes ejecutable.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.16.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.16.0 start script.
        npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T01_57_52_304Z-debug.log
          angeldchaveza @angeldchaveza
          @angeldchaveza .
          im delete display of "matefits71 " error logs view
          1 verbose cli [
          1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
          1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
          1 verbose cli ‘start’
          1 verbose cli ]
          2 info using npm@6.14.14
          3 info using node@v14.17.5
          4 verbose stack Error: missing script: start
          4 verbose stack at run (C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:155:19)
          4 verbose stack at C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:63:5
          4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:116:5
          4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:436:5
          4 verbose stack at checkBinReferences_ (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:391:45)
          4 verbose stack at final (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:434:3)
          4 verbose stack at then (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:161:5)
          4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:382:12
          4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:123:16
          4 verbose stack at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:73:3)
          5 verbose cwd C:\Users\Tecsis\MagicMirror
          6 verbose Windows_NT 10.0.19041
          7 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
          8 verbose node v14.17.5
          9 verbose npm v6.14.14
          10 error missing script: start
          11 verbose exit [ 1, true ]
            sdetweil @angeldchaveza
            @angeldchaveza u are on windows. there are extra steps for windows.
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
              angeldchaveza @sdetweil
              @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              these were the steps i followed
                @angeldchaveza yes, but they changed.
                my link has the updated steps
                  angeldchaveza
                  "Installing fonts …
                  "MagicMirror installation finished successfully!
                  magicmirror@2.16.0 prepare C:\Users\Tecsis\magicmirror
                  [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                  husky - Git hooks installed
                  npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                  npm WARN magicmirror@2.16.0 scripts[‘server’] should probably be scripts[‘start’].
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules\fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                  audited 923 packages in 21.766s
                  110 packages are looking for funding
                  run npm fund for details
                  found 0 vulnerabilities
                  Tecsis@DESKTOP-FGU3JGC MINGW64 ~/magicmirror (master)
                  $ npm start
                  npm ERR! missing script: start
                  npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T02_53_44_514Z-debug.log
                    @angeldchaveza do NOT install under
                    MINGW64
                    just straight windows
                    • K Offline
                      KillK
                      Hi, newby here… I have reinstaled MM in my win 10 laptop… It was working well until the reinstallation…
                      I am having an issue, i will try to translate it, cuz my cmd is in spanish…
                      magicmirror@2.17.1 start
                      “node_modules” doesn’t recognize it as an internal or external command,
                      program or file by executable lot.
                      At the same time i have notice, that “.bin” folder doesn’t contain “electron js” folder inside…
                      I have had to install manually npm for fonts ans vendor’s folders…
                      Please, help me Obi Wan Kenobi…
                      mumblebajM S 2 Replies Last reply Reply Quote 0
                      • mumblebajM Offline
                        mumblebaj Module Developer @KillK
                        @killk You have asked the same question in different posts a few times. This can be seen as spamming,
                        • K Offline
                          KillK @mumblebaj
                          @mumblebaj oh sorry, i have to delete the other one… I didn’t know it.
                            sdetweil @KillK
                            @killk we are all volunteers here. more folks around in the evenings, weekends. but it’s all volunteer. no commitment to answer any question or solve any problem . asking in multiple places doesn’t get help any faster.
                              sdetweil @KillK
                              @killk I had no problem
                              Win 10, under Vmware
                              git clone
                              npm install
                              and in vendors and fonts
                              edit the package.json
                              copy the default config.js from the sample
                              npm start
                                mounir @Mykle1
                                @mykle1 how can i resolve this ?
                                ‘DISPLAY’ is not recognized as an internal or external command,
                                operable program or batch file.
                                  sdetweil @mounir
                                  @mounir have to scan further back
                                  see
                                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                                    mounir @sdetweil
                                    @sdetweil no i see this
                                    listen EACCES: permission denied 127.0.0.1:8080
                                    can you help me fix it
                                      sdetweil @mounir
                                      @mounir where do u see that?
                                      u are installing in cmd terminal window, right?
                                      not PowerShell
                                        mounir @mounir
                                          sdetweil @mounir
                                          @mounir is this windows 10, or 11?
                                          never seen this. installed on windows 11 last week to test
                                          are u running any other web server apps?
                                            mounir @sdetweil
                                            @sdetweil i’m in windows 11 but there is no webserver running
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
