    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 876.5k Views 59 Watching
      mounir @Mykle1
      @mykle1 how can i resolve this ?
      ‘DISPLAY’ is not recognized as an internal or external command,
      operable program or batch file.
        sdetweil @mounir
        @mounir have to scan further back
        see
        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
          mounir @sdetweil
          @sdetweil no i see this
          listen EACCES: permission denied 127.0.0.1:8080
          can you help me fix it
          S M 2 Replies Last reply
            sdetweil @mounir
            @mounir where do u see that?
            u are installing in cmd terminal window, right?
            not PowerShell
              mounir @mounir
                sdetweil @mounir
                @mounir is this windows 10, or 11?
                never seen this. installed on windows 11 last week to test
                are u running any other web server apps?
                M 1 Reply Last reply
                  mounir @sdetweil
                  @sdetweil i’m in windows 11 but there is no webserver running
                    sdetweil @mounir
                    @mounir read this
                    https://superuser.com/questions/1437780/how-to-fix-listen-eacces-permission-denied-on-any-port/1568476
                    u can change the port in MagicMirror\config\config.js
                      mounir @sdetweil
                      @sdetweil thank you it works when i’m changing the port in the config.js
                        Note for v ersion 2.18 a little twist
                        do
                         npm install --only=prod
                        otherwise the developer dependencies will be installed too, and fail, causing electron not to be installed.
                        then
                        the additional steps are the same
                        cd fonts
                        npm install
                        cd ..\vendor
                        npm install
                        cd ..
                        and edit package.json to change the start line as shown in prior posts
                        new info for change of start line in package.json, with node 16
                        should be like this (earlier worked with node 14,)
                        "start": "node_modules\\.bin\\electron js\\electron.js",
                          Pearce
                          I went through the installation guide and got this error:
                          $ npm start
                          magicmirror@2.18.0 start
                            sdetweil @Pearce
                            @pearce further up
                            • N6NGN
                              N6NG
                              Hi all… Looks like a lot of people are trying this… I’m going for it myself but ran into this problem…
                              When I try to do the
                              git clone https://github.com/MichMich/MagicMirror.git
                              I get the following error.
                              N6NG@Main-Computer-in-Ham-Shack MINGW64 /
                              $ git clone https://github.com/MichMich/MagicMirror.git
                              fatal: could not create work tree dir ‘MagicMirror’: Permission denied
                              Anyone figured out how to change permissions… sudo isn’t recognized yet.
                              Dennis
                                sdetweil @N6NG
                                @n6ng no mingw,
                                just normal windows prompt
                                • swvalentiS
                                  swvalenti Project Sponsor
                                  @sdetweil I installed MagicMirror no issues on Windows 11 but get undefined on several modules. Here is npm start dev
                                  Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self'". Either the 'unsafe-inline' keyword, a hash ('sha256-+VvWeRXLFRBjsYaMznmUQGiO1Vl3+a2jdYPOrV4EIp8='), or a nonce ('nonce-...') is required to enable inline execution.
                                  main.js:481 Initializing MagicMirror.
                                  translator.js:128 Loading core translation file: translations/en.json
                                  translator.js:146 Loading core translation fallback file: translations/en.json
                                  loader.js:184 Load script: modules/default/alert/alert.js
                                  module.js:509 Module registered: alert
                                  loader.js:155 Bootstrapping module: alert
                                  loader.js:184 Load script: modules/default/alert/notificationFx.js
                                  loader.js:160 Scripts loaded for: alert
                                  loader.js:203 Load stylesheet: vendor/css/font-awesome.css
                                  loader.js:203 Load stylesheet: modules/default/alert/./styles/notificationFx.css
                                  loader.js:203 Load stylesheet: modules/default/alert/./styles/center.css
                                  loader.js:162 Styles loaded for: alert
                                  translator.js:107 alert - Load translationfalse: translations/en.json
                                  translator.js:107 alert - Load translation fallback: translations/bg.json
                                  loader.js:164 Translations loaded for: alert
                                  loader.js:184 Load script: modules/default/updatenotification/updatenotification.js
                                  module.js:509 Module registered: updatenotification
                                  loader.js:155 Bootstrapping module: updatenotification
                                  loader.js:160 Scripts loaded for: updatenotification
                                  loader.js:203 Load stylesheet: modules/default/updatenotification/updatenotification.css
                                  loader.js:162 Styles loaded for: updatenotification
                                  loader.js:164 Translations loaded for: updatenotification
                                  loader.js:184 Load script: modules/default/clock/clock.js
                                  module.js:509 Module registered: clock
                                  loader.js:155 Bootstrapping module: clock
                                  loader.js:184 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                  loader.js:184 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                  loader.js:184 Load script: vendor/node_modules/suncalc/suncalc.js
                                  loader.js:160 Scripts loaded for: clock
                                  loader.js:203 Load stylesheet: modules/default/clock/clock_styles.css
                                  loader.js:162 Styles loaded for: clock
                                  loader.js:164 Translations loaded for: clock
                                  loader.js:184 Load script: modules/default/calendar/calendar.js
                                  module.js:501 Check MagicMirror version for module 'calendar' - Minimum version:  2.1.0 - Current version: undefined
                                  module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                                      at cmpVersions (module.js:525)
                                      at Function.Module.register (module.js:502)
                                      at calendar.js:9
                                  loader.js:184 Load script: modules/default/compliments/compliments.js
                                  module.js:509 Module registered: compliments
                                  loader.js:155 Bootstrapping module: compliments
                                  loader.js:244 File already loaded: moment.js
                                  loader.js:160 Scripts loaded for: compliments
                                  loader.js:162 Styles loaded for: compliments
                                  loader.js:164 Translations loaded for: compliments
                                  loader.js:184 Load script: modules/default/weather/weather.js
                                  module.js:509 Module registered: weather
                                  loader.js:155 Bootstrapping module: weather
                                  loader.js:184 Load script: modules/default/weather/weatherprovider.js
                                  loader.js:184 Load script: modules/default/weather/weatherobject.js
                                  loader.js:244 File already loaded: suncalc.js
                                  loader.js:184 Load script: modules/default/weather/providers/openweathermap.js
                                  loader.js:160 Scripts loaded for: weather
                                  loader.js:244 File already loaded: font-awesome.css
                                  loader.js:203 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                  loader.js:203 Load stylesheet: modules/default/weather/weather.css
                                  loader.js:162 Styles loaded for: weather
                                  loader.js:164 Translations loaded for: weather
                                  loader.js:184 Load script: modules/MMM-News/MMM-News.js
                                  module.js:509 Module registered: MMM-News
                                  loader.js:155 Bootstrapping module: MMM-News
                                  loader.js:160 Scripts loaded for: MMM-News
                                  loader.js:203 Load stylesheet: modules/MMM-News/MMM-News.css
                                  loader.js:162 Styles loaded for: MMM-News
                                  loader.js:164 Translations loaded for: MMM-News
                                  loader.js:203 Load stylesheet: css/custom.css
                                  alert.js:47 Starting module: alert
                                  updatenotification.js:18 Starting module: updatenotification
                                  clock.js:48 Starting module: clock
                                  compliments.js:38 Starting module: compliments
                                  weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
                                  weatherprovider.js:46 Weather provider: OpenWeatherMap started.
                                  main.js:499 All modules started!
                                  module.js:94 Template render error: (updatenotification.njk)
                                    EvalError: Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'self'".
                                      at Object.n.t (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:2630)
                                      at n.i.render (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:37638)
                                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35783
                                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35581
                                      at o (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:35306)
                                      at http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64086
                                      at XMLHttpRequest.i.onreadystatechange (http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js:2:64326)
                                  (anonymous) @ module.js:94
                                  module.js:94 Template render error: (current.njk)
                                  weather.js:149 New weather information available.
                                  swvalentiS S 2 Replies Last reply
                                  • swvalentiS
                                    swvalenti Project Sponsor @swvalenti
                                    Lastly, all the modules I have working on another MM are not showing at all just blank. Is this a windows issue?
                                    • swvalentiS
                                      I scoured the forum and internet but can’t find anything on nunchucks I am guessing that is the issue.
                                        sdetweil @swvalenti
                                        @swvalenti did u run the extra steps?? (because the postinstall linux syntax fails on windows)
                                        cd vendor
                                        npm install
                                        cd ..
                                        cd fonts
                                        npm install
                                        cd ..
                                        now u can start
                                          sdetweil @swvalenti
                                          @swvalenti black screen
                                          see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                          swvalentiS 1 Reply Last reply
                                          • swvalentiS
                                            swvalenti Project Sponsor @sdetweil
                                            @sdetweil Hey Sam it’s not a black screen just modules show as undefined…like weather, news and components all other modules show
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
