    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 759.0k Views 59 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      @sdetweil also how do you not install under mingw could that be the issue
      Ok I did that but I’ll try again
      S swvalentiS 2 Replies Last reply Reply Quote 0
        sdetweil @swvalenti
        others don’t show at all like MMM-PGA
        i don’t know what “don’t show” means
        did u edit the config.js
        only a vew modules don’t work on Windows (snowboy voice driven for example)
          sdetweil @swvalenti
          note that u have to run the extra install steps manually too
            the position where the modules are supposed to show only a black black screen rest of modules work fine
              sdetweil @swvalenti
              maybe fonts or the nunjucks… (from vendor folder)
              swvalentiS 1 Reply Last reply Reply Quote 0
                swvalenti Project Sponsor @sdetweil
                @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                I did the fonts but no clue what nunjucks is and how to fix it when I googled it I only got pictures of nunjucks
                  sdetweil @swvalenti
                  @swvalenti nunjuks is the web content templating code, which some of the modules use (it generates the web content from a ‘form’ like definition)
                  but that will not be installed if you do not npm install from the MagicMirror/vendor folder
                    Ok offially at a lost oh well it was worth a shot to try
                    swvalentiS S 2 Replies Last reply Reply Quote 0
                      @sdetweil as an example MMM-PGA shows this in dev
                      module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                          at cmpVersions (module.js:525)
                          at Function.Module.register (module.js:502)
                          at MMM-PGA.js:9
                        sdetweil @swvalenti
                        @swvalenti here are the windows instructions
                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1647717794843
                        • 23
                        • 24
                        • 25
                        • 26
                        • 27
                        • 32
                        • 33
                        • 25 / 33
